Test drive advice?
Posted by: Paul Hutchings on 30 January 2005
OK, so tomorrow I have a test drive of a 1999 BMW 323Ci booked.
It's Topaz Blue, auto, leather, air-con, boot cd-changer, 1 owner IIRC, 43k miles and is at a BMW dealers as a BMW used approved car for £12k.
I took a look at the car today, it's in the compound and has not been prepped for sale as of yet.
Bodywork looks fine, alloys are mint - it may seem a small point but I don't want a car with scuzzy wheels.
There are some scratches that I noticed and I did say to the salesman that if I was interested in buying the car I would want to be very clear on what would be taken care of versus what would be considered "expected for the age".
The interior looks very good, it's light grey and coming from a car with a black interior it seems very "bright", but I didn't see anything that looked badly marked/scratched.
Engine started first time, usual dealer thing of 1l of fuel in the tank but the engine was very quiet and under the bonnet looks immaculate.
How should I handle the test drive tomorrow?
The salesman said the way he usually does them is that he'll drive first as it gives me chance to experience the car without having to concentrate on driving it, also he explained that as salesmen test drive cars all day it's a way of seeing if it's doing anything he wouldn't expect it to do. Then it's over to me, he did say the test drive can be as long/short as I want within reason.
Really I'm after suggestions on how to deal with it as it's all to easy to walk away forgetting everything of any importance.
Would it be considered bad form to bring a digital camera and ask if I could take some pictures of the car?
cheers,
Paul
cheers,
Paul
Posted on: 30 January 2005 by long-time-dead
Things I would want to do.
Drive on roads I know. You will get a "feel" for any differences over your usual drive.
Pull away from a slow speed in a high gear. This will give a quick check on the clutch and also be an indicator for transmission slop.
Drive on motorway.
Ensure wheels are re-balanced and tracking is checked and aligned if required before purchase.
Forget the salesman. He is there to sell, not to make a friend.
Get written agreement for any "fixes" that are deemed necessary.
It's your cash - be as picky as you want to be !
Drive on motorway.
Posted on: 30 January 2005 by Berlin Fritz
Sound advice that man, spoken like a really good agg, and a Scotch one at that, innit.
Fritz Von As our Mat always say's, knowing something and understanding something are seprerate entities entirely
Thank you for your sincerity..........
Posted on: 30 January 2005 by HTK
Take a dictaphone. You can use the dealer's lounge facilities to write down any issues after the drive and use the list as the basis of a haggle.
There will be plenty of suspension and road noise. With the sports suspension you need to do some sweeping cross country stuff at speed - any thumps or bangs under those conditions should set the alarm bells off.
Check for smelly climate control, (esp on auto recirculate)and perfect operation of windows (those frameless jobs are really cool - until the seals wear out or the track allows the window to miss its top slot). Brake judder and front wheel shimmy need to be addressed if present. 'They all do that' is a perfectly true statement - but they're not supposed to. Other than all the electrics working you shouldn't have much else to worry about. If it feels good it probably is good.
Any roughness in starting or running whatsoever is a walk away. There shouldn't much or any hint of vibration all the way round to 6000rpm. These engines are turbine smooth. Likewise, any clonkiness with the transmission. the Step gearbox is a peach. It has no foibles. If it feels wrong then don't buy.
Also have a look at what the warranty covers. If it's an approved used BMW the cover is VERY comprehensive. Also dertermine what service is due next. Even with a recent service, you are going to need one at some point. An Oil servive is around £100. Inspection I is a bit more than double and Inspection II is the wrong side of £400. Check which one is due next and haggle accordingly.
Good luck.
Good luck.
Posted on: 30 January 2005 by cunningplan
If you're thinking of buying a BMW then this is a must read!
Clive
Clive
Posted on: 30 January 2005 by manicatel
Check air con works ok,& when next service is due/how much.I had a pig of a time with the wife's 3 series with the driver seat bearing/rails. Basically, when you went round a bend/roundabout, you could feel the seat "click" into a new position on the rails. Only by a couple of mm,but v. annoying, & the dealer came out with the usual "they all do that sir"crap.Also, drive it on the type of roads that you normally use, preferably without the salesman.They will distract you from any bad points, & it's easier for you to closely inspect the car without him/her on your shoulder.Enjoy it, best of luck, matt.
Luvvly Jubbly, and of course taking a dictaphone doesn't mean bringin yer mate along !
Posted on: 30 January 2005 by MichaelC
Paul
Simple advice - if in doubt walk away, there are plenty of vehicles out there.
Mike
Mike
Posted on: 31 January 2005 by Brian OReilly
No known problems. Tramlining normal on 225 section tyres - 205 section optimal. Headroom not as good as saloon. Should come with comprehensive 1 year warranty. New coupe still 1-2 years away - no effect on pricing of this particular car.
Concentrate on getting stone chips/scratches/cosmetics fixed before sale - mechanical problems covered by warranty.
Test drive it as you would normally drive your own car to see if it's suitable.
Not an incredibly fast car, but perfect specification. Should pose no resale problems in future.
No idea if price is high or low I'm afraid.
BOR
Edit: You might be able to negotiate an extra couple of years of warranty more easily than moving them on the price.
BOR
Posted on: 31 January 2005 by Deane F
Originally posted by MichaelC:
Paul
Mike
Seconded. It may be obvious or already known, but it bears repeating: you must be prepared to walk away from the deal at any time and it matters a lot with cars because they're such money drains.
Deane
Posted on: 31 January 2005 by Hawk
Paul
You already have some very good advice re the test drive from the posts above from people who know more about the car than me, so i wont add to that part, however i would advise that you also put as much preparation into the haggle itself!
The advise about getting the scratches sorted as part of the sale is very valid, but if you make a big song and dance at the outset the salesman will factor this cost into his opening offer. It maybe better to haggle the best price you can first, then when you cant push him any further on price agree to the sale subject to the fixes you want. Its also important that you agree how these scratches are to be fixed. eg polished out, panel respray (not always best) or a 'chips away' type repair. Be careful about your body language too, good salespeople are experts at reading customers. Your body language really will give the salesman a clue as to how likely you are to give in to his price. Think interested but not too keen, and when he mentions that another customer wants to see the car, as im sure he will, make like he has put you off altogether and look at his body language! Cross your arms everytime he says something you dont like, and when you feel close to the deal try uncrossing just one arm. That will give the signal that the salesman has a chance to close the deal, but he still has a little way to go...
Above all just play the game and try to enjoy yourself!
Good luck!
Hawk
Good luck!
Hawk
Posted on: 31 January 2005 by Bruce Woodhouse
Buy the car not the salesman. A car you are not sure of, sold by a friendly salesman who is prepared to haggle on all the things you mention, is still a car you are not sure of.
Whatever you do compare it against others, it is not as if the model is very scarce. The best test drives are done twice too-first time often feels too strange to really get all you want to learn if the car is not familiar too you.
I just drove several cars whilst choosing a new one for my wife. Going back a second time also proved to the dealer i was serious and moved the prices that bit more!
Bruce
Bruce
Posted on: 31 January 2005 by HTK
Re minor chips. Should the car be very much to your liking but you can't agree about the odd minor chip, 'Chipsaway' will come out and make them vanish for not much money.
Harry
Harry
Posted on: 31 January 2005 by Lomo
Why not a nice Rover.
Posted on: 31 January 2005 by Paul Hutchings
No such thing as a "nice rover" IMHO
Thank you all for your advice so far, it's appreciated.
I'd like to think I have my head screwed on and, as others have said, there will be other cars tomorrow if this one seems to have gremlins.
It'll be interesting to see how it drives and how the power feels, to me a 2.5l 180bhp car sounds a lot compared to "only" a 75bhp 1.4 Golf!
I suspect I'm getting hung up on things like scratches in paintwork but I would assume that, so long as the dealer is willing, pretty much anything can be taken care of so that they aren't visible when the car has been prepped?
At the moment, AIUI it's in that stage where it arrived at the dealers and go put in their holding compound - given the area this dealers is in I have a feeling they put the pricer stuff out first.
So far as body language, like to think I'm fairly good at the mind games, though I do tend to prefer being straight with people which can be a hinderence more than a help.
Interesting on the new Coupe - I knew there was a new 3-series on the way but didn't know how far off the coupe would be, but I do think I recall the salesman mentioning at least a year.
It seems I'm not over too many barrels, don't need finance, cash is in the bank so there's no "I'm doing you a favour" card that the salesman can try and play.
Keep the tips coming!
cheers,
Paul
cheers,
Paul
New 3 series in March. Touring late 05, Coupe some time in 06. I believe tha E46 Coupe is going to be a classic - never say never but I'll be very surprised if they can top the current model. They missed the mark by several million miles with the new 5. 3s look to be in good supply for a range of prices - you can pretty much please yourself because there'll be plenty more where that came from.
Posted on: 31 January 2005 by Huwge
If you are moving from a Golf to a BMW and have not driven a rear wheel drive before, then make sure you give it a spin on a wet road if you intend giving it a bit of welly.
It may not be so bad in UK, but Alpine B roads can be really fun in the winter time.
Posted on: 31 January 2005 by Chunny Nochubb
If you have not seen the bmw approved car website it is very comprehensive and you can search for models countrywide to ascertain market value
If it is an approved used bmw, as HTK says their spec is very comprehensive, (the website says 12 months on almost everything including mot Introduction to Approved Used BMWs
obviously they are keen to maintain their image.
I bought a 1 1/2 year old compact 2 years ago, from an approved dealer. They did show me everything on the car and made me sign a form to say they had. we found that the folding mirrors did not work, and they fixed them prior to delivery.
I imagine that the ground clearence is lower than your golf, so if you live in an area full of speed humps, you will have to drive very slowly.
Posted on: 31 January 2005 by Tristram
I would also ask to see a safety inspection report, which I assume the dealership would do before offering it for sale. In this report you will discover the condition of the various parts, specifically the brake pads and rotors. See if you can find out what repairs have been done. This will give you an idea of what to expect in the future. Also look for a record of servicing and oil changes if possible.
tw
tw
Just got back.
I think the short answer is that I like 3-Series Coupes, just not that specific car.
As a driving experience it was "interesting", started first time, quiet running, smooth, no smoke, roughness etc.. this probably says more about what I've driven but I've never driven anything so bloody quick, you plant your foot on the A-Roads and it just goes, yet it just pootles around the town centre. This one had an "adaptive" auto box with a sequential shift (forget the exact name) option if you flick the lever to the left.
The problem was the condition of the car, too many scratches on the paint, bit tatty basically.
I like to think I'm a fairly good judge of character and the chap I was dealing with seemed honest enough and didn't put an ounce of pressue on me.
After the test drive he asked me what I thought and I told him I liked the car but not that car because of the condition, he said he's been there since October and has a problem with the vehicle preparation at that dealers as it tends not to happen until the vehicle is either sold or going on the main forcourt - they have a compound out the back where the new and , I think, cheaper used BMWs.
As I said to him, how can you decide whether or not to buy a car when you can't see it anything near the condition you would expect it to be in? I suggested to him they probably concentrate on the more expensive cars as there's more money in them and he said it shouldn't really work that way but did sort of grin when I said "yeh but it's economics that a dealer will put more effort into a car that makes them more money". Oddly he then got his briefcase from under his desk and got out a flowchart he'd been working on which is how he wants the "a new used car arrives" to "customer drives off" process to work.
I then started enquiring what other cars there were in that sort of price/model range. They have a 1999 V plate, one owner 318Ci with 17k on the clock for similar money, pretty standard spec plus metallic paint/wood trim, boot CD changer.
Looks in very good shape but I said I'd go do some homework before deciding if I wanted a test drive as I don't know if it would be a bit underpowered for quite a large car.
All in all seems a bit chicken and egg, need to drive a range of cars to see which one fits the bill.
Weird really, just not at all what I expected from a BMW used car salesman, quite refreshing, hard to sum it all up but I'm still trying to work out if he's a bloody good actor or on the level
Thoughts on the 318Ci appreciated
Paul
Paul
I ran a 318Ci (W-reg) for three years without any big problems. The driver's door window needed fixing because it missed the top slot but that was fixed under warranty.
A remarkably swift car for its capacity - note the auto box on that model is 4 speed (your test car had 5). You don't get silver interior trim or electric seats. But the biggest missing benefit is the beautiful straight six.
The gearbox you tried today is a Stepatronic. IMO one of the best autoboxes you can buy today.
A 318Ci will have the same box if it's an auto (minus the fifth cog).
I did just short of 100k in my 318Ci. It was refined, comfortable, fast enough and ran like clockwork. With the exception of two pin sized dents it looked as good (inside and out) on the day it left me as it did when it first came off the flatbed truck.
All E46 Coupes are equiped at SE spec level. The only thing left out is the front centre armrest. Post summer 2000 models get a trip computer, white lenses, multi function steering wheel and rear PDC. It's quite an equipment hike for the sake of what might be a few hundred quid on a S/H exmple. But the biggest plus on post facelift 2000 models is the quicker steering rack. Combined with the nice chunky (multi function) steering wheel it made a significant difference to steering feel and accuracy.
Biased? Yes I am actually. With the exception of the car I'm running now it was the best car I ever had.
Stone chips. A classic side effect of tailgating. If a prospective purtchase looks like acne you have ask what sort of idiot was driving it, and how much care they took of it. In 40k in my present 5 Series, I haven't picked up so much as one stone chip (although it's had a few other dings and bangs). This is because I don't drive like a BMW driver! Didn't get any on my (black) Coupe either. I'm surprised I was allowed to drive it....
Later model 318Ci has 5 speed autobox - probably not within your price range yet - not sure. The 1.9 Valvatronic engine came in about 2-3 years ago. A lovely engine but again, probably still to expensive S/H. There wasn't much wrong with the older engine mind you.
If I was you I'd be keeping an eye out for an early 320 Coupe. Introduced with the facelift in Summer 2000. 2.2 straight six, five speed Step auto, no electric seats. A real little beauty but possibly still a bit over 20k - but well worth investigating.
FWIW
Harry
FWIW
Harry
Posted on: 31 January 2005 by woody
When I last test drove it was ZM Coupe . Needless to say I bought it there and then. Awesome bit of kit.
Since then all BMWs I've driven have seemed - well, dull. The 323 is good for what it is - a small exec saloon. However, - despite what the salesman tells you - it is not an M3 or a sportscar.
Posted on: 31 January 2005 by MichaelC
Can't comment on the 318Ci but we have a 318i saloon (2001 post face lift) which is reasonably swift. Although not a six cylinder it is a smooth engine. Other comments:
Handling is good and communicative.
Reasonably taught suspension.
Seats are ok - but then with the exception of my current car I have a lot of difficulty finding a comfortable seat position (honourable mention for a Datsun 260Z I had though).
Fuel economy is ok - returns on average low thirties (combination of short runs and slightly londer runs of say 30 miles).
Build quality is exemplary - the only problem was the front number plate falling off!!!
Interior finish is very good. Space is fine in the front but tight in the back ie similar to the coupe.
The climate is good although vents for freah air are only average.
My local dealer (Coopers, Banstead) is excellent from the service point of view and costs are modest.
Mike
Mike
Coopers have a very good rep. One of the better dealers - so I'm told.
