Use UK NAP90 in USA with transormer, convert to 110V or upgrade ?
Posted by: Cookiemonster on 14 March 2004
I have recently emigrated to the USA with my NAC92/NAP90, and added a Flatcap to the NAC92. I have been using the NAP90 with a mains step-up transformer (Voltage Valet, http://www.voltagevalet.com/catalog.html). Sources are LP12/Lingo/Ittok/Karma and Linn Genki CD and speakers are Mission 702e (clearly the weakest link).
After asking my local Naim dealer to convert the NAP90 to 110V, I found that Naim USA insist on the unit being shipped to them for the conversion, at a cost of $250. Since this seems possibly more than is worth spending on it, I would be very grateful for advice on my options
1) Have Naim USA do the work on the NAP90
2) Continue to use the NAP90 with mains transformer (any opinions regarding the effect of using this on the sound gratefully received)
3) Upgrade – but how far ? My dealer has a tempting used NAP250, but how well would this go with my NAC92/Flatcap and Missions ?
Many thanks
Andy
Many thanks
Andy
