Should I CDX?
Posted by: Tim Williams on 20 April 2004
Currently running a Micromega Duo 3.1 / Duo Pro (bitstream) DAC through 102 / 180 / Flatcap into PMC FB1's (well I like them!)
I've not really listened to the Micromega for ages, but I'm trying to build up the CD side of my system (without spending a lot of money).
The question is, I guess, does the CD front end need replacing? It is an old machine now but very highly regarded (and hugely expensive!) in its day. Has CD 'technology' moved on significantly in the last twelve years or so?
I'm thinking of a CDX (a nice recentish one if I can find one), but no realistic possibility of adding an XPS for years (or at all!). Is this a good idea? Any other recommendations for around the £1,500 mark, new or used?
On a 'technical' level, what type of DAC does the CDX use? (I've trawled through all of the Naim site and can't find any information). What sampling rate is it (if this is the correct term) - bitstream, multibit (and, if so, how many bits?). Do the older players (CDX, not CDXII) incorporate the HDCD 'decoder'? Is any of this actually important?
A lot of questions I know, but I would be grateful for any help.
Cheers!
Tim
Cheers!
Tim
