I ordered the latest interconnect to go between my CDX and 82. I was under the impression that it was black with a tinge of lavender. However, the cable that arrived was gray. It was lighter than my existing gray SNAIC5 at the office. (I've not been home to compare it to the existing cable on the CDX.) I suppose I could convince myself that there's a bit of lavender in there too, but it's virtually subliminal.
Have I got the right cable, or is there another one out there? I know this question was covered in depth on the old forum, but I can't search for that anymore, can I?
Thanks in advance for any info.
BTW, I also got two black SNAIC5's to go between my 82 and the Hi-Caps. I just tried one between my 32.5 and SNAPS2 at work, and the difference was clearly and immediately evident: The sound was less edgy, smoother and more cohesive; everything flowed better, with less "jangle". I can't wait to get them home. Catch you later!
-=> Mike Hanson <=-
Smilies do not a forum make.
Posted on: 11 August 2000 by Rico
Basically, it's pretty grey. Has a slight tinge of "lavender"... but it's still grey. Like all cats in the dark, etc...
Re the black SNAICs, congrats - it's worthwhile, eh?
Now try the new NACA5 - you should be more than a little surprised.
Rico - musichead
ricomuzik@hotmail.com
Posted on: 11 August 2000 by Andy S
Mike,
IIRC, the lavender cable wasn't much different to the grey cable (in sound terms). The big upgrade is the black SNAIC.
Evidently, Naim have improved the power supply part of the cable and since the CDX->82 interconnect doesn't carry power, there isn't much improvment in the lavender cabling.
Andy
Posted on: 11 August 2000 by Mike Hanson
I'll give it a listen at home, and decide whether it's worth the cost. I'm also about to get a Cambridge CD6 here at work, and it has balanced outputs. Hence, I could convert the old home interconnect to use the appropriate output connect on the CD6. (That's assuming that the CD6 is better than the D500; I purchased the CD6 sight unseen, but I have a friend who's willing to purchase whichever one I don't want.)
BTW, I forgot to mention that I also got an extra puck, just in case my other one goes missing someday. I'm probably just being paranoid, but the small cost is worth it for the peace of mind. Catch you later!
-=> Mike Hanson <=-
Posted on: 11 August 2000 by Former member
Mike, when I got my CDS2 my dealer pointed out the distance in the interconnects and was careful to keep the (old) CDX one apart. I subsequently got a (new) interconnect for my NAT03. On plug in there was quite evident "difference", cleaner and more open but a little "glassy", hard to describe, not totally natural. Wondered if it was a mistake, decided to give it a few days. It was there for a day or 2 then disappeared quite obviously, one day was gone. Never thought of it since.
Audibly, the new 'lavender' snaic effect seems much more subtle than black snaic upgrade. Black snaics are really worthwhile, I'd rate this one as optional.
Visually, the lavender is subtle, its more of a sheen or tint. From memory they're also a different thickness.
Posted on: 12 August 2000 by Mike Hanson
I appreciate the extra info. I haven't had a chance to install the cables at home yet, so I'm still chomping at the bit. Catch you later!
-=> Mike Hanson <=-
