Hum with P9 and Stageline
Posted by: Steve C. on 12 April 2004
I now have my P9/Denon DL-103D hooked up to the Stageline, and am getting hum. It goes away when I have the TT unpluged from the Stageline. Tried floating grounds on the TT power supply and the FlatCap to no avail. I believe I read that it was possible to disconned the ground inside the P9, but I didn't follow how to do that. I will say that, listening around the hum, the Stageline is doing some very nice things compared to my EAR834P, even just powered from the 112 (need to get a 5 pin to 4 pin cable to run it from the FlatCap.)
Any thoughts or suggestions would be appreciated. Thanks!
Posted on: 13 April 2004 by Chris Murphy
Hi,
The turntable hum you are describing may be because the system is not attached anywhere to mains earth. Try running a lead from the earth of a mains plug, plugged into the wall, then attach it to the earth terminal of the stageline. Is there a CD player attached as well? Does the hum go away if this is disconnected? Let me know how you get on.
Best,
Chris Murphy.
