Hi cap repair info required
Posted by: Fisbey on 23 April 2004
I recently got a Hi Cap back after repair / overhaul (from Infidelity), but no repair info was supplied - The Serial Number was 150104 - any help please?
Admin?
Posted on: 23 April 2004 by greeny
Yes The insides were replaced by a new 24v battery and a brick to maintain that weighty quality effect.
In all honesty how the hell are we expected to know what was done to your HiCap. You need to contact your dealer, or Naim service depatment directly
Tel: + 44 (0) 1722 332266
Fax: + 44 (0) 1722 412034
E-mail: info@naim-audio.com
Posted on: 23 April 2004 by Richard Dane
Fisbey,
your Hicap was given a full service involving replacement of the main caps and tants and was put on soak and tested OK.
If you need to know more about servicing, I suggest you contact either Infidelity or speak with our service department.
Richard
Posted on: 23 April 2004 by Fisbey
Er Greeny
That's why I wrote - Admin.
Thanks all the same.
Richard - thanks
I'm just being facetious
I did try to help with the contact detail though
Posted on: 24 April 2004 by Fisbey
Greeny - no worries - thanks
