CD5i DIN/RCA Simultaneous Output?
Posted by: tubelistener on 22 April 2004
I know the CD5i has both DIN and RCA outputs. Is it possible to use both simultaneously, the DIN connected directly to a NAIT5i and the RCAs to an older tube amp I own? This will allow easier switching between the two amps while still utilizing the same source. I was told that the CD5i had an internal switch that you could select between DIN or RCA, but can that switch be set to drive both outputs?
Posted on: 22 April 2004 by Hawk
I know you can on the CDX2 as i have the din going to a 282 and the phono going to a tube headphone amp working as you describe...
if you go to the following link it has all the naim manuals so you might find the answer there
http://216.149.62.210/products/intro_manuals.html
Posted on: 23 April 2004 by Robbert
Another question about the CD5i: What formats does he play? I hear; CD/CD-r/CD-rw/ but also MP3? or sometings else more
And how are your experients for so far with the CD5i?
NAIM: NAIT5 / REGA:Radio,Planet /
CHORD: Cobra 2 / Dynaudio: Natural One
Posted on: 23 April 2004 by prowla
The meaning of the symbols is pretty obvious. "O" is DIN and "oo" is RCA. "O oo" is both.
Shouldn't the big "O" have 5 dots in it, and the small "o"s have 1 dot?
Big Grin (how we larfed!)
Paul
Posted on: 24 April 2004 by Steve O
Naim will tell you for optimum sound quality to only select one output type. I think it can be done via the handset though, so this shouldn't prove to be an obstacle.
