Nait 2 - to service or not? Remixed
Posted by: Craig B on 13 March 2004
Sigmund
Member
posted Tue 09 March 04 17:02
I'm the proud and original owner of a Nait 2 integrated amp. On and off, I think about sending it in to be checked out and serviced as needed. A couple of years back, I spoke with a tech at the Chicago site who said that as long as it wasn't giving me any trouble, I should call back in another ten years. Last year, I called again and I could hear the guy on the other end of the phone drooling at the thought of getting $450 or my hard earned dollars because nothing less than a complete overhaul would do. What have any other Nait 1 sor 2 users done? I don't want to give away my $$ unnecessarily. On the other hand, while my unit sounds *great* to me, I don't think I'd know if it's slipping a little. Thanks.
Posts: 75 | From: Pittsburgh, PA USA | Registered: Wed 16 January 2002
PR
Member
posted Tue 09 March 04 17:20
sigmund
I could rest your concerns if you want to sell your little Nait cutie?
Posts: 975 | From: RTW | Registered: Thu 25 July 2002
Sigmund
Member
posted Tue 09 March 04 18:18
P, my long lost friend. I knew I could count on you to relieve me of my misery and compassion. Let's talk sometime, say, after another 35 years or so when my wife and I are so old that we couldn't tell the difference between our trusty Nait 2 and a can or okra. Stay in touch.
Top Cat
Member
posted Tue 09 March 04 19:00
It's well worth having the Nait 2 serviced - it can be an incredible injection of musicality and life into the wee amp - but $450 is a severe case of taking the piss. I'd reckon no more than $150 - I paid £40 to have mine done, including new caps, display, power chord, a good clean and some other bits & pieces. That translates to around $80.
John
Posts: 2127 | From: The Fife Riviera | Registered: Tue 24 October 2000
PR
Member
posted Tue 09 March 04 20:29
Top Cat
Do you want to sell yours?
Sigmund
Member
posted Wed 10 March 04 02:37
Top Cat, did you have yours serviced by a dealer or by the distributor? Thanks.
Top Cat
Member
posted Wed 10 March 04 07:45
Mine was serviced by a Naim approved dealer using the Naim Nait2 update 'kit'. My £40 price may have been subsidised by the fact that I was also having an Armageddon, Cirkus and Helikon added to my LP12 at the same time - so perhaps I got the Nait kit at cost?
John
Top Cat
Member
posted Wed 10 March 04 07:47
Anyway, it's technically my wife's - the 52/SC/250 is mine. I could sell it and make a tidy profit but then I'd regret it, I am sure of it...
John
PR
Member
posted Wed 10 March 04 08:45
Top Cat
I envy you. We have a 62/140 in the bedroom, which is largely used by my other-half. However, with selling my main system, I need a short-term plug. I'm considering the Nait5i - new sound and all that, but wonder how it would compare to the Nait 2? The 5i certainly loses on cutie looks IMO.
mykel
Member
posted Wed 10 March 04 16:38
Just an FYI for Canadian's
I just received a reply from Jean-Luc at Dimexs regarding recapping my Nait 1.
Quote
The cost is 278.00 including parts and labor but no shipping and tax(es).
We change 17 capacitors and reset the bias.
Endquote
I also got a quote on my 160 - same deal, excluding taxes and shipping - $434.00 Canadian.
This is on March 10, 2004.
regards,
michael
Posts: 271 | From: Citizen, Planet Earth - The Canadian Part Eh!! | Registered: Thu 18 January 2001
Craig Best
Member
posted Wed 10 March 04 16:25
Hmmm, I only paid $Cdn 300. for my 1985 edition NAIT 1 just last year (a veritable bargain over here in Canada).
Spending another 300. plus dollars doesn't really appeal for what won't exactly be a fully restored amp considering that the key moving bits and connectors will all still be 19 years old.
For that matter, doesn't Naim HQ's service department change out things like DINs and speaker output sockets as a matter of course should they appear to have seen better days? Shouldn't their distributor's service departments be also offering the same level of service rather than simply substituting new caps and re-setting bias? Or, is that what you asked for a quote upon Michael?
Thinking DIY for a moment, changing out the relevant caps appears a pretty straight forward job as long as one carefully observes correct polarity and properly re-mounts the output transistors with mica insulators and thermal coupling goo intact.
I wonder what's involved in re-setting the bias? The pots appear to be conveniently positioned atop the main board just aft of the output transistors. But, what of the relevant input vs. output values for the old NAIT? Presumably one needs little more than a decent scope and the relavant numbers to do the job properly. Anyone know the official details? (a PM will do thanks)
For that matter, what are the audible symptoms of out of spec bias voltage? I've heard tell of the odd younger amp going off and needing nothing more than a bias adjustment. Perhaps such adjustment accounts for much of the perceived improvement brought about by a full amplifier service?
Any thoughts?
Craig
Posts: 600 | From: Canada | Registered: Mon 31 July 2000
mykel
Member
posted Wed 10 March 04 20:27
Craig
I believe I used the phrase " service / re-cap ", figuring on my end that would entail the full monty.
It was mentioned that Target HiFi may be willing to do the service, If so, Dimexs would send down the cap's but they would have to do the bias adjustment. From this I would take that the service is just what you mentioned, the re-cap and bias check. (unless other work is specified or visual inspection indicates otherwise?)
Does seem kinda steep, if I remember correctly I picked up the wee beastie quite a few years ago now for the unheard of sum of 400.00 CDN, and that was off of the Naim dealers "previously enjoyed" section.
Problem is as mentioned on phone the other day, I just lost a channel, and it is the amp unfortunately. Maybe I will ring up Target and see what they have to say. Beats postage and the wait-time....maybe....
regards,
michael
Posts: 272 | From: Citizen, Planet Earth - The Canadian Part Eh!! | Registered: Thu 18 January 2001
Member
PR
Member
sigmund
Sigmund
Member
Top Cat
Member
John
PR
Member
Top Cat
Sigmund
Member
Top Cat
Member
John
Top Cat
Member
John
PR
Member
Top Cat
mykel
Member
Quote
Endquote
regards,
michael
Craig Best
Member
Any thoughts?
Craig
mykel
Member
Craig
regards,
michael
