Some Naim Impressions and Questions
Posted by: AT on 28 March 2004
In a rather extraordinary attempt to downsize, simplify, and avoid tubes for a number of reasons I'm trying out a Naim system. I demo'ed Naim a couple of years ago and liked it, but went the tube route instead. Right now I have a NAIT 5i and CD5i in my system, the NAIT with only several hours on it and the CD5i with several days on it. Here are some impressions and related questions.
There is great presence with the Naim. It sounds very live. Coming from all tube system, including a tube DAC it sounds more electronic, but appears to be smoothing out over time. The CD5i has been great so far! Both Naims ahve good detail, not too much but enough to give a good view of the performance and still be musical.
First, at low volume the Naim seems to lose its luster. Will this improve over time? Low volume listening is very important to me.
Synergy. I'm using my old speaker cable, Audience Au24. I've read here that it does not go well with Naim, though the new NAIT 5i seems more flexible with other cables. I'm also using the stock DIN interconnects instead of my Au24. I really want to avoid having to explore new cables. Any recs? My old system was highly synergistic and it took a long time (and money) to get there. I'd like to short cut this time. My dealer recs Naim cable, but I've read too many negative things about it to consider it.
Speakers. my current speakers are Tannoy D500s and as I've said worked great with my larger system. What recs do you have for the Naim? I've read that the Spendor S5e, which fit perfectly into my downsize scheme, are great with Naim. Others? Would prefer floor standers instead of monitors that require stands.
I have them on Neuance platforms.
Finally, there is room left in my rack to include a seperate amp and preamp. If I like the NAIT 5i will I love Naim seperates? What will improve with seperates? I may consider an upgrade to the CDX2 if things pan out too.
One more thing: the design of the Naim components is fabulous and the fit'n'finish is tight. I love the styling!
Thanks!
Posted on: 28 March 2004 by woody
The stuff is still "cold". Leave it on all the time, preferably playing music, and give it a couple of weeks. Stay with the standard interconnects.
NACA5 is pretty much essential.
-- woody
Posted on: 28 March 2004 by hicapman
Hi AT, I will be watching this post with interest as I currently use a CDX with an Icon audio valve integrated and Audio note speakers.I love the sound of Naim source components but couldnt get on with their amplification, just not 'my' sound.Are you downgrading because you have to or are you bowled over by the Naim sound, PRAT,dynamics etc?
Posted on: 28 March 2004 by AT
I realize it's early. I'm patient. I'm downsizing for domestic bliss reasons. My wife has learned that a good system is important to me but in trade she's asked that we reduce the complexity of the system. That and we'll eventually have kids and want less clutter, prefer less clutter anyway. The Naim PRAT did appeal to me in my demo some years ago; I can still hear it clearly in my head. But as I listen to the Naim I'm beginning to realize it does some things extremely well, but perhaps tubes are like drugs for me. They take the music to the next dimension and I become totally enraptured. There is excitement and there is bliss. As I learn more I guess I'm the latter. The leading edge is distinct with Naim and the music moves along convincingly, but the decay is missing. I think this has more to do with SS and tubes than anything else. Nothing's perfect and we're seeing what choice we can live with.
But, as I said, it's early. Time will tell. Nonetheless, the Naim CDPs have me captivated.
Posted on: 29 March 2004 by MichaelC
AT
It is early days. As has been mentioned before it needs to be kept powered up and over time you will really notice what it is capable of. I certainly find low volume listening in the evening to be quite fine.
Mike
Posted on: 29 March 2004 by kuma
AT,
I don't think this is a tube/SS thing. I think this is more to do with *which* tube and solid state gear we are dealing with.
Naim gear is perfectly capable of producing both excitement and bliss. ( older Naim has somewhat failed on the latter, imho, however )
Decay is missing? hmm.. interesting. I found it quite opposite in my case.
Posted on: 29 March 2004 by yaman
I absolutely agree with Kuma.
It also depends on which levels of equipment you are comparing. CD5i and Nait5i are the very first steps in the Naim ladder. If you have a chance to audition a 202/200 duo, I am sure most of your perceptions will improve in a big way. I recently went from 112 to 202+NAPSC and the difference is hard to believe.
Yaman
Posted on: 29 March 2004 by Betton
Hi AT
don't underextimate the Nait5i.
Leave it always on and listen again in 4 or 5 days. I think you will be surpised.
Cheers, Betton
Posted on: 29 March 2004 by Markus
When comparing your nait5i/cd5i setup to your former tube system keep in mind that, as mentioned above, you are on the first rung of the naim hierarchy. As such, a comparison to higher priced tube equipment might understandably turn out in favor of the tube equipment.
Regarding Naim's ability to properly resolved decay, I suggest you seek out oppportunities to hear other equipment and setups. As mentioned above, a 202/200 setup, preferably with a hicap, might provide the insight you are seeking.
If budget constraints are a factor in your decision to "downsize", keep in mind that used equipment provides incomparable value for money and holds its value quite well. You might enjoy an 82/hicap/140 system, for example.
For me personally, I simply became tired of having to replace tubes and periodically fuss with my equipment. I like the simplicity of naim. I set it, I forget it, I listen to it--simple as that.
It will be fun to hear your ongoing comments as you continue auditioning the naim equipment...
Markus
Posted on: 29 March 2004 by ben r
Hello I own both tubes and naim, def need to let it run in for awhile even weeks, I find I like them both, but I primarily use the tubes on my Khorns, I have been using naim speaker cable for years (also Linn cable) and like it very much, alot of audiophile cables simply dont sound very good, they cost a fortune,but sound mediocre, have you even tried the Naim cable?...also try to hear a 202/200 combo compared to what you have, I think you wil be impressed..
Posted on: 29 March 2004 by AT
The NAIT has already opened up a lot and smoothed out. I'm liking it more and more! I had to switch it off to replace the banana plug adapters that the dealer gave me (freebie crap floating around their office desk drawer -- not even a matched pair) with a pair of Radio Shack adapters. I'm getting a pair of Cardas adapters from a friend that I use with my Tannoys to great effect. Not sure how the speaker length effects things.
Posted on: 29 March 2004 by joe90
I really enjoy what the Nait5i/CD5i does for the price. Try a CDX2 on the Nait5i and get ready to be absolutely blown away!!!
I'm not a big Tannoy fan personally, but I'd say the D500s are a little under-driven. They're quite large and IMO the D300 would be better suited to the Nait5i.
NACA5 is a requirement, not an option.
5 pin DIN cables are mandatory. The Stock Naim is best. Check out Martin Colloms' review of the Cardas Golden Reference rca cable vs supplied Naim DIN in the recent Hi-Fi News review of the CDS3. Surprising results based on performance vs price.
Joe90
Oh, apparently I misunderstood. I thought that AT was simply "trying" naim equipment out. I didn't realize an initial purchase had been made. My understanding is that the 5i series offers very good value for money. Otherwise I would think that recommendations to shop for higher-tier used equipment might guarantee more satisfactory performance, in comparison with his apparently expensive tube system...
Markus
Ok, referee here Smile The 5i system does in fact offer tremndous value! Yes, the tube components are expensive and they're not leaving without a fight! But with the bigger goal of simplifying combined with the impression that the Naim is making things look good for Naim.
If you care for an update here it is. The Naim system continues to improve. As I listened tonight I found myself forgetting about the system and simply being drawn into and enjoying the music. It's really fun. Lots of great to discover again on those CDs. I'm trying some classical right now to see how it fairs. It's the largest growing category of my CD collection right now with jazz following closely.
It's sounding better at low volume. There still is a sense that it is somewhat closed in, but this may be a speaker synergy issue because the Tannoys require a high current amp while being fairly efficient. Plus, hey it's still early.
Another looming question is my power conditioner which is a Blue Circle Music Ring. I know Naim is against any power filtering at all but 1) I need additional outlets and 2) the Music Ring has worked perfectly so far so why not try it out. But if in fact it does reduce dynamics (and in my experience the Music Ring does not) what the heck does one use as an outlet extension that does not cause problems in some other way? FWIW, I do have a dedicated circuit for the system.
The fact that the 5i components are essentially a new design intended to be more compatible with other brands of interconnects and speaker cables as well as components makes me wonder where the higher levels of Naim are heading. In other words, does one wait to see about this before upgrading?
Regarding NACA5, I've review after review and many comments that say it can easily be bettered. I've not tried it myself though I am using the stock gray DIN interconnects. While there is some snake oil in the cable market several cable companies have created some great cables. I would think that it would be challenging for Naim to keep up with this area while they focus on making their components top notch.
What else can I say; this is fun Razz
Posted on: 30 March 2004 by Greg Beatty
"My wife has learned that a good system is important to me but in trade she's asked that we reduce the complexity of the system."
Hum...do you know what she means by 'complexity'?
Perhaps having an amp on the floor between the speakers bothers her...or its the number of visible boxes...or the spiderweb of cables...
All of these can be addressed above the 5-series.
Also, my wife considered 'complexity' to be about using the system. Our system connects to the tele, DVD player, VCR, etc. so its a bit more complicated than just choosing a source.
The answer was a HomeTheater Master 500MX remote. We push and hold for two seconds any source button and a macro is started that configures everything for the chosen source.
A godsend if ever there was one. It has replaced 7 remotes and I've not had to go back to the originals in months.
- GregB
Insert Witty Signature Line Here
Posted on: 30 March 2004 by Emil
Welcome to sanity, AT
You remind me alot of myself about a year ago.
I was looking to downgrade, simplify things even at the expense of sound. I had a pair of Reference 3a Decapos coupled with an Atmasphere s30. Expensive cables, power cords,
and a bunch of isolation devices. I bought Cds that were recorded well even though the music was awful... your typical audiophile.
Go ahead, make a clean break and dont look back. You know its right Wink
