Isolated Ground
Posted by: kevroy on 15 April 2004
I've got a dedicated mains spur feeding a single outlet for my system. I'm considering replacing the outlet with an isolated ground unit, which I'd connect to it's own earthing rod. Anyone tried this with positive results? Also - any comments on a dedicated mains spur vs. ring? (A ring loops the wiring back to the circuit breaker)
Posted on: 15 April 2004 by Martin Clark
Where are you located, and what do you know about your electrical service? It has a large bearing on what you can do...
As you describe it, don't do it - driving your own earth stake to provide sole grounding for the hifi's power socket is NOT safe (for several reasons) nor will it be an improvement on using the supplied earth.
But that doesn't necessarily mean you can't improve on your current situation. Smile
M.
Posted on: 15 April 2004 by ken c
M.
absolutely. for example, depending on how your supply is delivered, if there is a break in your service earth circuit, your dedicated earth MAY end up being THE only working path to earth. imagine that!
enjoy(?)
ken
a spur (or more correctly, radial) is better, as adviced in almost all naim manuals.
enjoy
ken
Posted on: 15 April 2004 by NaimThatTune
Hi Kevroy,
1) Two radials (spurs) are better than one ring. I can't say I've compared these with the same grade of wiring but in general the idea of putting spurs in is to seperate components from other devices that the mains feeds. A ring will common together various bits of your hi-fi - which are best kept apart.
2) Earthing schemes vary greatly depending on when your house was built/what may have happened since. As posted before, if your house shares an earth connection with a number of others in the vicintiy and the earth connection is faulty somewhere, the most direct path to earth may well be through your (proposed) spike. The term 'consult an electrician' spring vigorously to mind!!
To answer your question a correctly installed earth can increase the clarity quite noticeably - for reasons not quite understood (by me anyway)...
Cheers!
Richard.
