Addictive game
Posted by: JeremyD on 21 April 2004
I was just sent this game. All you have to do is click on the red square and move it so as to avoid hitting the sides or the moving blue rectangles for as long as you can.
red square game18 seconds is supposed to be a good time but after five minutes of trying (during which I mostly survived for less than two seconds) I reached 30.48. I'm not terribly well coordinated, so
much better times must be possible - unless the blue rectangles speed up repeatedly.
Posted on: 21 April 2004 by Thomas K
Jeremy, good fun. After a couple of tries I got as far as 25 seconds -- it speeds up at some point, doesn't it?
I think the trick is not to look at the blue squares or the perimeter, but to keep your eye on the home square as you move it.
Thomas
Posted on: 21 April 2004 by andy c
LOL.
Managed the 18 second bit ok but then struggled to get past that time....
andy c!
Posted on: 21 April 2004 by JeremyD
Yes. I just tried the game again, made the same moves twice in a row and got zapped after 24s through being caught out by the speed-up.
Posted on: 21 April 2004 by Steve B
Just over 20 seconds after about 30 goes. My finger aches now though.
Small things.........
Steve B
Posted on: 21 April 2004 by Simon Perry
You can do the first ten seconds sitting in the top left hand corner. Even so, i still can't get over 20. Doh!
Posted on: 21 April 2004 by Mekon
Third go, 92.784.
Posted on: 21 April 2004 by Former member
0.88 amongst other scores
Tom
Actively enjoying it all
Well done Tom! Mekon - are you a robot? That is just wierd (but very well done!).
Posted on: 21 April 2004 by NaimThatTune
Up, no left, down a bit... Aaarggh!
21.54s so far.
Cheers!
Rich.
P.S. You've seen the size of the Mekon's brain?
Posted on: 21 April 2004 by seagull
Best so far 25.1, worst .11.
If you move fast enough you can go through the blue rectangles...
Simon - clearly a fluke, most of mine are in the 40's, and my best since that is 72.815.
