Handy thing, wives...
Posted by: Top Cat on 20 April 2004
Hi all...
You might recall that recently I added a Prefix K to my LP12 to replace the K boards in my 52. However, from the start the Prefix wasn't working properly in the context of my system - there was no particular improvement in the sound over the K boards (all powered by 52) and the Prefix suffered enormously from static popping and to a lesser degree from RFI breaththrough.
Having decided to check out other options, I decided I'd remove the Prefix and re-fit the stanard cable. Problem is that for some inexplicable reason, whenever I lie on my back and try to work on something above my head, I start to feel queasy and can end up sick. Weird, I know, but then that's how it is.
Anyway, I successfully removed the prefix but was having some difficulties fitting the Aro cable once again (holding a torch in my mouth, one hand holding the LP12 steady and the other trying to manhandle the tiny Aro connector plug screws into their positions. I began to feel very sick, as if I'd been spinning round a lot. I know that sounds strange, but bear with me.
ANyway, my good lady returned from her jewellery class and I asked, somewhat sheepishly, if she could help attach those screws. No problem. However, she didn't stop there - before I knew it she was sorting out the P-clip and doing all the stuff that I thought was the elusive preserve of the LP12 initiates. Was I impressed!
Just goes to show - never under-estimate your woman...
John
PS. Deck sounds FAR better sans prefix (no pops, quieter, more musical) and I'm delighted again. A demo of a P75 awaits, but to be fair I could live with the K boards if push came to shove.
John
