Copying CD's
Posted by: Arye_Gur on 26 September 2000
In Israel CD's are too expensive.
I wonder what the members here are thinking about
CD's prices, about copying CD's - did anyone
checked if a copied CD is equal to the source
CD (I think it is not) and I'm interested to know anything else connected to this subject.
Posted on: 26 September 2000 by Former member
I have a Philips CDR 765. I have made several copies and on most examples the difference is very slight if non - existent. This is even when played on my 'best' kit ie:
CDX/XPS, 82/S'Cap, Snaxo/HiCap, 250x2, SBL, Mana 4 tier Amp stand x 2. On something that's very well recorded eg. Eva Cassidy 'Songbird' there is a slight loss of presence - less open - but on merely good recordings the difference is so slight as to be negligable.
For the cost (£175 2nd hand) I rate it as an excellent buy.
Kevin
Posted on: 26 September 2000 by Vik
I use a CDS1 on a Mana Phase 3.
The rest of the system is a (temporary) 32.5, supercap, passive 135s, an 02 and sbls. The rest of the rig is on a mana 6-tier, the sbls on mana platforms.
The trouble is this. When I want to record I remove the CDS from the Phase 3 and put my 765 on the Phase 3 instead. The 765 is allowed to warm up, to which end, discs are played on both the play and the record side.
Before recording, the source and copy discs are washed, dried, given the bedini ultra-clarifier treatment and finally 1 statmat per disc before recording. So it is a meticulous process, though not fanatical, if you know what I mean. And recordings are done only when the least number of appliances in the house and (presumably) neighbourhood are turned on, my separate spur notwithstanding.
I'd expect damn good recordings - which is to say I don't get them.
I experienced a lack of interest when playing back a copy, which I put down to poor timing qualities of the recorded disc, plus some rawness.
So essentially, I am just wondering if the problem is in the recording side - could it be the recording side is not run-in enough? did you have initially the same results? I've recorded maybe 4 hours worth of music, tops. The lack of interest I experience also occurs when I monitor the playback via headphones - the Sennheiser HD600 is pretty useful.
Thanks in advance,
Vik
Posted on: 26 September 2000 by Arye_Gur
I'm not as Pro as Vik.
I find that sometimes there is a adifference in volume between copy and source Cd. I find it amazing because all the data in CD is a digital data and this includes the "instructions" about
the level of volume. If there is a different in volume there must be a different in other factors - but how? As a programmer I know that if
you copy a digital data from one media to another - as for the didgital matters the data is the same - but how can it differ when we use it
with our Cd players.
Most of my friends who have a standart stereo systems are claiming at me that there is no differences at all. But we with our better equipment feel differences.
Maybe it is because of the different in depth of the copied data on cd comapres with depth of data
on the original - if it is how can it be ?
If there is a difference, I'm sure all the music
companies at the world should shout it loud and prove that copied discs are inferior to the
original - so if there is a different how comes they are sitting silently ?
Maybe something wrong with our ears ?
Arie
Posted on: 27 September 2000 by Martin Payne
Arie,
the copies aren't a patch on the originals.
Used with a CDX they reduce the performance of the player to much less than a 10 year old Arcam two-box.
cheers, Martin
Posted on: 27 September 2000 by Former member
Martin is right.
I used to have a Philips CDR, and made copies from the digital output of my old Rotel CD player. Copies often lacked transparencies and detail, although I was (later) told it mainly depends on the quality of the CD that is being recorded.
I sold my Philips CDR when I realised I was using it to make copies of my CD collection for my friends.
Moreover, copies often didn't work on my Alpine CD player in my car, while still work on my girlfriend Sony CDP in her car.
Stefano.
PS
I absolutely agree on the (too high) cost of CDs all over the world:
CD (box included): say 0.5 UKP?
Copying process (large scale production): say 0.3 UKP?
Cover, lyrics, labels: say 0.8 UKP?
I'd like to know how the remaining 10 (approximately) are shared among artists, production companies and so on.
PPS
It is obvious that a lower price would decrease illegal copies and increase turnovers.
I have found the quality depends on several factors:-
1) What you use - some machines are better than others, and the best I have found is using a PC and some decent copying software.
2) It also depends on the quality of the blanks used. Some are terrible.
3) CDR and CDRW provide different results with different kit.
4) Yeah - sometimes they just don't work - especially in Naim kit. Don't try using > the standard red book length (c75 mins?) 'cos it probably won't play.
5) It is never quite as good as the original - even with the good PC option. Wierd - not sure why. Sounds silly with digital - maybe something to do with error checking??
6) Unless you make copies for your own use ... it is illegal just about everywhere. Careful.
I used to use a friends PC set up to do the occasional compilation disc to help with things like auditioning - but eventually stopped because of the quality issues. However - I will now get me own copying set up, because :-
1) My firend has moved to the other side of the world and taken his PC with him.
2) I've just ordered a car with BOSE Hi-fi and 6 cd multichanger. So I can do stuff for the car without worring about the copy quality 'cos the engine noise will be x10 worse, AND keep the original safe.
I've made a number of CDRs on my PC, and yes the results do vary.
Allways, allways try to copy realtime. Double speed will usually work but gives inferior results.
Recordings made at quad or highet speed often refuse to play on my Cyrus or Naim player.
Even realtime copies sound a little flat & 'dirty' compared to the original - but still enjoyable.
Use good quality branded discs too like TDK, Kodak, or Maxell.
Rob.
Vik,
I have taken nothing like the care you have with recordings and I have still been very pleased with the results. The CDR I bought was second hand and so did not appear to need any run-in period.
Kevin
Posted on: 27 September 2000 by Arye_Gur
About the kind of blanks, I understand that for
some reason the color of the surface is important
for quality. So I tried to find blanks with the
same colors of the original (like pure silver)
but can't find them. All TDK and Maxel blanks
are with colord surface - I heard the best is the golden color.
But as I see most of us feel that the copied one is not like the original and I realy want to understand how it comes - it is a wonder for me.
Comapring on a computer the copied one is the same as the original.
Arie
But as I see most of us feel that the copied one is not like the original and I realy want to understand how it comes - it is a wonder for me. Comapring on a computer the copied one is the same as the original.
Arie.
As a pure reading of data, the copy is identical, but when it comes to recreating music, the timing of the 1s and 0s is important and this is not perfect in the copy.
BTW--what are you doing up so bloody early??!! I know I've been bugging people about silly nicknames, but you my friend have earned the right to use "Milkman."
Vuk.
Posted on: 27 September 2000 by Vik
"CDR I bought was second hand and so did not appear to need any run-in period."
Thanks Kevin, this is some useful feedback for me.
I'd thought to use green ink on the edges too. While it would've helped recordings it would've sounded dead on the Naims.
This tweak had served me well from the Meridien MCD (remember that?) onwards till I bought my first Naim CDP. After which I spent many annoying evenings removing it all.
I can't remember if it was this process that affirmed in me that EVERYBODY ELSE was Flat Earth, and Naim was Round AND green.
Best
Vik
Posted on: 28 September 2000 by Arye_Gur
Hi Vuk,
First - I'm going to measure the difference in time between the 1s and 0s on the original compares to the copy.....
If you are right, maybe the solution is on the
copying programm like Green Anorak suggests.
I'll check it with the computer experts at my work. Vik (if I understand him well) thinks that
the laser beam while copying dosn't do the same job as in the original - and the blank material
is not like the original too and that makes the diffrence.
About the cows, I don't remember when I saw one... I live in Haifa which is a city (the third in number of population in Israel and the first in industrial areas).
In Israel - as the sea shore goes from North to South, Haifa lies on a mountain (Carmel mounatain but we have no connection with Clint Estwood) that goes from East to West and reaches the sea. The mountain is 1500 feet high - and there is a wonderful view here - many people and tourists claim this is one of the most beatiful cities in the world.
I have milk from the supermarket nearby my home...
Tomorrow we have a holiday here ROSH HASHANA which
means "Year's head" and this is the beginig of our new year - we celebrate this holiday but we live our life according to the Georgian calander.
That's something about life here - I hope it is not boring.
Arie
[This message was edited by Arie_Gur on THURSDAY 28 September 2000 at 17:08.]
Posted on: 28 September 2000 by Jez Quigley
First of all it is illegal although it is generally accepted that you can make one 'backup' copy for your own use if you own the original.
The best method is is via a PC. Don't use the cheapo blanks. Traxdata and TDK are OK. Don't buy the ones marked 'audio' they include a rake off to the phono industry but don't sound any better. Use a good quality cd -writer - the best is Plextor although Sony are close. Use good CD mastering software like WinOnCD or Nero- I don't like the results from Adaptec. Contrary to popular belief recording in real time is worse, not better. This is because modern writers will over-cook the pits at such a low speed. Try 2 or even 4 speed. Vuk is again expressing views about something which he clearly has little knowledge. I find that SOME copies sound even better than the original, possibly because the PC extracts the digital code and lays it down on a nice pristine surface that the CD player can read with less error correction. The bottom line is that if you follow the above, most of your copies will be just as good as the originals, even on 'superior' systems. (I've tried them on a Linn Karik, Ikemi & Genki, and my friend's Meridian)
aaa101,
I'm writing your instruction and going to work acording them.
Thanks,
Arie
Posted on: 28 September 2000 by P
Fascinating stuff - nice one vuk!
Regards P.
Posted on: 28 September 2000 by Former member
Pierre O'Lounaire?
Vuk
Posted on: 29 September 2000 by Former member
Hmmmm, errrrrr, Arie ? Are we talking about the same Haifa, the city that never wakes up and has an ugly port in the front and refineries at the back ???
It may be prettier than Tel-Aviv, but that's not saying much...
Pierre O'Lounaire?
Can it be Pierre is actually Pierre Cardin but since his tie empire is going down he is only using his first name ?
Or maybe Pierre Channel the 5th ?
Posted on: 29 September 2000 by Arye_Gur
Hi Omer,
Like many Israelies who don't know Haifa and speak
only about the port and refieneries, I sugest next
time when you are here let me show you the city
from the Carmel (I will not ask you to sweem at the port.....)
Arie
Arie, you're too damn serious. I know a bit about Haifa and visit it from time to time (Technion, the Carmel, Haifa university, and I had friends in Neve Shaanan) and although I don't think it's one of the most beautiful cities in the world I think it is nice and much prefer its looks to probably any other city in Israel, and damn, you have the only decent Naim dealer here.
SHANA TOVA,
Omer
Posted on: 29 September 2000 by Andrew L. Weekes
My experiences correlate with many above - the copy is not a patch on the original, even when played through a modest system.
I've been trying to find out why for a number of years now - I've tried different CD writers, software and discs.
I am veering strongly towards the opinion that the discs and/or the physics of the writing process is the primary source of the differences.
The blank CDR disc has a track manufactured onto the disc, that is used to guide the laser, and more importantly I believe, to provide timing information.
There is a sinusoidal 'wobble' on this track, at a frequency of 22.05kHz (1/2 of the CD sample rate), that is used to control the disc's rotational velocity. I assume it is used to control a PLL to keep the disc spinning at the correct speed. Errors in this track, and poor PLL performance would impact sound quality dramatically.
Additionally, the time taken for the recording dye to change state when being written to by the laser could also introduce timing jitter.
My belief is the above would produce the type of sound I'm hearing from the copied CD's, i.e. poor rythm and timing, missing low-level detail and a generally harsh unpleasant sound. This is exactly the effect I get if I introduce more jitter into the master clock in my CD player.
I have noticed that some manufacturers (e.g. Philips) are advertising some CDR discs as 'low jitter' I will try some and see if there are any differences.
Andy.
Andrew L. Weekes
alweekes@audiophile.com
Posted on: 29 September 2000 by matthewr
I agree that PC is the way to go (if you have one that is) - FWIW Nero seems to be the very popular with musicians for use in home/project studios which possibly says something about its audio quality. The other one with a godd reputation for sound quality is Audiograbber.
aaa101 said:
>> I find that SOME copies sound even better than the original, possibly because the PC extracts the digital code and lays it down on a nice pristine surface that the CD player can read with less error correction <<
Although in most cases copies sound at best marginally worse I've heard other people claim improvements as well. There are theories that copying provides some kind of de-jittering effect, or that a new copy allows the player to read the CD more realiably and the consequent reduction in movement of the laser reduces noise from the servos and so reduces noise in the analogue stage of the CD player. However noise correction is definitely not a factor as 99% of the time error correction has no effect on sound quality.
Matthew
aaa101's contribution looks promising but while I may occasionally want to copy CD-CD, my main need is to CD-ise LP's (and also perhaps FM) through my pre-amp.I think we have Plextor and WinOnCd at work, so can you recommend the best sound card and-or A to D converter to use?
System is: good-spec LP12/Audiolab 8000T tuner/CDSII/NAC52/NAP135's
Posted on: 29 September 2000 by Steve Catterall
that's a bit like asking for the best CD player - it really depends on how much money you're willing to spend.
The best ones tend to keep the A to D converters away from the PC - i.e have a break out box which connects to the PC via a card.
There is lots of information on digitizing sound on the Sound On Sound Website(which is a magazine for digital musicans. They also have lots of reviews etc.
>> so can you recommend the best sound card and-or A to D converter to use? <<
If you've got a fairly new PC with a USB port then the EGO-Sys Waveterminal U2A features high quality 24bit DACs and is good value at approx $270 USD. Details are on thier web site (Note that if it asks you to install a Korean language pack say no as the site is in English).
Otherwise the pro market leader for many years is the Digital Audio CardDeluxe at approx $500 USD.
Sorry I don't have UK prices although you can either buy over the WEB or a trip to Tottenham Court Rd a a bit a haggling should result in a decent UK price.
Matthew
