Guitarists - Anyone bought a POD recently?
Posted by: J.N. on 22 October 2004
Ahoy there axemeisters
I've just succumbed to 'version 2.0' of the venerable effects box. At £130 (new) I couldn't resist.
Haven't tried it yet, as my Telecaster is currently being fettled, and having a new switch fitted.
I just wanted to check that I have everything I should have. The dealer says yes, but there was a piece of squarish cardboard in the box covering nothing.
So basically; I have the POD itself, instruction book and a mains transformer.
Anything missing?
Ta.
Posted on: 22 October 2004 by Rockingdoc
I got some software on a CD, but lost it before I used it, so it can't have been very important.
Posted on: 22 October 2004 by Jez Quigley
I have a POD2, the software is available from the Line 6 website along with new tones etc.
Posted on: 22 October 2004 by Not For Me
I have Pod 1, it came with mains, book and CD.
The software allows midi editing of the amp models and effects - adding a bit of fun.
I'm waiting for the Variax workbench to come out!
DS
ITC - Robag Wruhme - Wuzzlebud KK
*** All the views expressed within this e-mail are the sole responsibility of DS, and as such are subject to chaining ***
Posted on: 25 October 2004 by Stephen Bennett
J
I have the CD if you want a copy.
I love my Pod.
Now you need a Poddleboard.
Enjoy!
Stephen
Posted on: 25 October 2004 by J.N.
Thanks Stephen; I'm not au fait with all this computerised management of effects lark.
I've only just worked out what to do with the knob that goes up to 11 on my guitar amp.
Presumably the CD contains more effects which may be loaded into the POD from one's PC?
How then are these additional/replacement effects accessed?
Ta.
John.
Posted on: 26 October 2004 by Stephen Bennett
Ta.
John.
The CD has a PC version of an editor allowing you to control all of the PODs parameters from the computer and save/load patches. I'm not sure you can actually access all the POD from the front panel - I've never used it!
Stephen
