Help with Excel needed
Posted by: Markus S on 25 April 2004
Guys,
I must be doing something stupid.
I'm working on an Excel spreadsheet which I have been sent by someone else.
It's extremely simple: there are a few columns, but I'm only using two of these right now.
In one column, I'm entering payments (positive or negative), the next column is supposed to give me the sum total of all payments
So we have
Line 1 payment 1 sum 1
Line 2 payment 2 sum 2 = sum 1 plus payment 2
Now the problem: I can't get the damn thing to perform the caluclation. In the second column, I keep getting repeats of sum 1, instead of sum 2 ... n.
What am I missing?
Posted on: 25 April 2004 by Don Atkinson
you might find that the formula for sum 2, sum 3, etc has a cell reference that is "fixed" ie has $ signs such as "$a$2". It probably needs "relative" cell references ie without the $ signs, such as "a2"
the error is most likely to be found in either the "sum 1" formula or the "sum 2" formula
hope this helps
cheers
Don
Posted on: 25 April 2004 by Markus S
Don, thanks for the answer; the formula seems to be correct. The problem seems to be that Exel wants to be told that it has to execute the formula. Is there a button for that?
Posted on: 25 April 2004 by Former member
Markus
Assuming your maths is right and you have allowed for the absolute referencing that The Don mentioned, have you checked that the spreadsheet it auto-calculating?
Press F9 - if that recalculates sum2, then go to Tools>Options>Calculation and make sure the box for Automatic is checked.
ag
Thanks folks, found the mistake - I had somehow opened the excel sheet in Word.
Posted on: 25 April 2004 by David Stewart
Yup - that would do it Wink
Markus,
good on you.....the solution would never have crossed my mind......ever.
but I had put out a contract with one or two of my "family" to find a solution for you.....i'll close those now and on this occasion, for the benefit of ag, there is no obligation...
Don
Posted on: 26 April 2004 by Markus S
Don, it was one of those "Doh!" moments.
