Apple Ipod again
Posted by: Robbie on 02 September 2004
For those in the know.
Is it possible to use the Ipod as a storage device for digital photo's from my Nikon D2h ?
Rob.
Posted on: 02 September 2004 by garyi
Well yes and no. You can't use it directly but Belkin do a devise which plugs into the ipod and allows you to insert media cards which are uplaoded to the ipod.
If however you mean images from the computer the ipod can be treated like a removable harddrive and any files can be stored on it
Posted on: 02 September 2004 by Robbie
Thanks Garyi,
So I can use it as a portable storage device then ?
Rob.
Yup, if you are in windows it can be set thorugh itunes, right click the ipod and properties
Garyi,
Found the device from Belkin on the internet.It's called Belkin IPod mediareader and costs 130 E .
Now I've got an alibi to buy myself an iPod (the 40gb version).
Rob(Mac-user).
snigger, thats the one, its pricy, but I guess they can charge what they like, they are the only ones producing it.
