Naheed,
removing the mains switch may sound like a good idea, but I think it's short-sighted.
How are you going to power the system up?
It is never a good idea to plug a live mains lead into a switched-on appliance - you can get funny surges, and Naim kit really does not like surges up the neutral power line (ref JV on old conference).
Even if you've got a switched mains socket (I bet you haven't, given this question) then you will have to switch everything on all at once - against the advice in the manual to switch on the power amp(s) last. At the very least this will give you a big thump through your speakers, and this is never a good idea.
(For info, my dealer reckons that a single loud squeal from plugging a phono socket into the live source on a preamp is sufficient to deteriorate the tweeters on your speakers).
Although this may sound better in the short term, I would worry that in two or three years you may have unnecessarily stressed your electronics or speakers and be getting a sound which is less than it might otherwise be.
Be careful.
Have a happy New Year, Martin
