Where to hear Orbe and Naim
Posted by: Richard P on 03 May 2004
Hi
Anybody know where to hear a Michell Orbe and Naim amps, preferably in the Home Counties/London?
Also, will an Orbe fit onto a Fraim glass shelf? (If the answer's No, please ignore the above question!)
Richard
Richard
Posted on: 03 May 2004 by neil w
richard
your'e welcome to come to mine , alas its in durham, and yes orbe will fit onto a fraim BUT the power suply wont it does have a long interconect lead
neil
neil
Posted on: 03 May 2004 by woody
Cornflake will be able to oblige.
-- woody
-- woody
Posted on: 03 May 2004 by Wolf
I heard an orbe at my dealer's recently here in Los Angeles when I went to pick up my CDX2. It was really amazing, very smooth and detailed presentation. I know I'm going to have to have big bucks to upgrade my lowly Planar 3. It also had the Michell tone arm, don't know what cartridge tho a year ago he was oohing and aahing about a Koetsue (sp?) he'd loaded for a client. So maybe he got one for himself. The whole demonstration was with a 282 w/2hicaps and a 200 amp and Quad speakers. It was a really wonderful demonstration tho far too short.
glenn
Life is analogue
glenn
Life is analogue
Posted on: 04 May 2004 by Laurie Saunders
Richard
I have an Orbe/SMEV/Lyra Helikon feeding:
K Prefix/Hicap/52/Scap /135s/ProAc Response 3.5s
Pop over if you want to hear it
Laurie S
Laurie S
Posted on: 04 May 2004 by Andrew Randle
IMHO a P9 or LP12 is better, so don't forget to listen to these too.
Andrew
Andrew Randle
Linn Binn Sinner
Andrew
Andrew Randle
Linn Binn Sinner
Posted on: 04 May 2004 by Richard P
Neil, you have a PT
Richard
Richard
Posted on: 04 May 2004 by Martin C
Hi Richard,
You are really wise to ask that question? As I bought the AVDI DIVA in March. i assume that it would fit nicely on the fraims, as I bought fraims the same time.
The answer is problem, DIVA is not with spike, but big trunky feet, plus motor. Having checked with Naim, they would not specially made a bigger size glass shelf, which I am quite upset to spend two and half grand for the racks!!! |They ask me to make myself my own glass shelf!
Having check with AVID, they have a new isolated platform, but not sure the feet will be sit nicely on the fraim glass.Still waiting for their reply.
So what should I do. The turntable is home and I am not able to listen to it.
Any suggestion, anyone? Should I just take the fraim galss to a glass shop and ask for a toughen glass with the same tinted colour? Is there any special about fraim's glass shelf?
cheers
Martin
cheers
Martin
Posted on: 05 May 2004 by Richard P
Thanks for the replies.
Andrew
I already have an LP12, and am considering changing my 15 year old Ekos I to either an Ekos II or an Aro, or changing the turntable altogether, and I shall also be checking out the P9. I didn't want this to turn into a "which turntable is best" thread, interesting though that might be.
Laurie
You have a PT
Richard
Andrew
Laurie
You have a PT
Richard
