Speaker positioning
Posted by: Paul on 11 November 2000
Thanks in advance and again, sorry for the cross post ![]()
Grunt
Could other SBLs users possibly post their distance between them to see if there is an average/consensus. From experience I realise the best way is to experiment but I am hoping to angle grind a 12mm channel in the floor of the new house to hide my NACA5 and get it WAFed around the fireplace and wanted to get the placement right to save headache later
Thanks guys
My SBL's are 8ft apart when measured from tweater to tweater and I sit about 11ft away. They point straight out and are 5" out from the wall in order to bring them just out in front of a chimney breast. They sound good.
Mick
The Credos I had before were the same but I thought needed 6 inches or so out from the wall. tried toe in but it seemed to go wrong with this.
Bruce
due to space constraints I listen pinned to the back wall 113" away, or outside barbequing with the neighbours. The room is 159" wide and 127" deep, with a charming curved sun-trap window corner. There are no knitted/crocheted toilet-roll covers disguising round-earth tube-traps.
I can vouch for the sound being gut at Devs, despite an American turntable in operation. Health and Safety notices should be errected to warn potential theives, as the weight of that slate slab would arise in a personal injury claim should someone try to run off with it!
Rico - ok, the Kans are sorted, now whatabout the rainforests?
PS - mine no longer sound good, as the power amp has now vanished.
I can confirm that a Sony ICF-SW7600G sounds rather good on Mana.
