I need the exact dimensions in inches for the headline headphone amp
Posted by: Jaybar on 30 October 2000
my shelf aspace is tight, so I need to know exact dimensions in inches BEFORE i buy. Thanks.
Posted on: 31 October 2000 by ian
4 3/4" wide, 2" high & 7" deep
power supply about the same size. I stash the power supply underneath my rack (out of sight) & the Headline sits on top of my Amp.
Thinking about it, I should test to see if the sound is effected by sitting it on the Pre or Power.
ian
