Allae Crossover "Mod"
Posted by: Greg Beatty on 29 May 2004
My Allaes have sounded great and I have no regrets of the purchase. But...
...in my room, they don't quite do the "band is in the room" thing that some other speakers I home demmed were able to do. I believe this is a quantity of bass issue as the speakers that did the "live" trick were bassier.
To find out more, I have been exploring room modes, moving the speakers around, and finally got a Radio Shack analog sound pressure level (SPL) meter. Used in conjunction with the bass, midrange, and treble warble tones on Stereophile's Test CD3 and the published-on-the-net correction values for the meter, I measured the in-room response using my Sony ES series CD player and Panasonic DVD player as sources. Both sources measured the same.
The response graphs I got were nearly identical to what Stereophile reported for the NBL. Not saying Allaes are NBLs, but the Allaes definitly have the same frequency response signature. A drop off of 3db starting at 500hz on down and a rise in the mids and treble region.
A bit more research turned up the notion of baffle step. Baffle step is drop in forward radiation of bass frequencies that "wrap around" the baffle of the speaker. The frequency of the step is determined by the width of the baffle - narrower baffles beginning the step at a higher frequency than wider baffles. So I plugged the width of my Allaes into the equation and - wouldn't you know it - the baffle step starts at 500hz!!!
The usual remedy is for the speaker's crossover to include components to compensate for baffle step. The maximum decrease in bass is 6db, which is subjectively half as loud. Naim assumes (or so I have read - moderators feel free to correct if I am wrong here) that the baffle step bass drop will be addressed by placing the speaker near or flat against a *solid* wall and the lost bass will be redirected back into the room. This is the "boundary reinforcement" that we read about from time to time.
Well guess what. I moved my Allaes flat against the wall...took measurements in different places in the room...and even placed the Allaes *in the corners* trying to get additional boundary reinforcement from the side walls.
No dice. I moved some of the resonant frequencies around a bit, but the overall 3db drop remained. Oh, and I don't know if the Allaes have partial baffle step correction and so that is why I measure -3db instead of -6db or if they have no correction and my walls are partially reinforcing the bass. In either case, bass to match the mids and treble is impossible in my room without some adjustment.
A bit more research and I find this:
How To Correct Baffle Stepwhich explains a very simple crossover circuit to correct baffle step. And the "mod" is in quotes because the simple circuit is placed in between the speaker wire and the crossover - no need to actually change the Naim crossover, just need to do the baffle step correction prior to the speaker.
The "mod" consists of putting an inductor and a resistor in between the speaker wire and the speaker. Dead easy.
So I have ordered two 1.5mH inductors and I already have 8 ohm, high-wattage resistors. So for less than $20 including shipping I will be able to add baffle step correction to my Allaes. The inductors are probably not very good at $5 each, but I want to try the concept before shelling out for better inductors.
I see no reason why this couldn't be done with any speaker as the circuit is standard when building crossovers.
I will write back when the baffle step correction is up and running.
- GregB
Insert Witty Signature Line Here
Posted on: 29 May 2004 by Andrew Randle
Let us know what it does to the all-important phase response...
By all means give it a go, but I reckon your foot won't be tapping to the music as much.
Andrew
Andrew Randle
Linn Binn Sinner
Posted on: 29 May 2004 by Mr.Tibbs
"The "mod" consists of putting an inductor and a resistor in between the speaker wire and the speaker. Dead easy."
I don't want to piss on your fire, so to speak, but I can't see what good that'll do. Try it anyway, but I'm fairly certain it will just reduce the low freq's still further.
You might be able to get slightly more drive out of the existing bass unit by changing the low pass inductor for one having a lower DC resistance.
Hopefully James will drop in and set the record straight.
Mr Tibbs
Posted on: 29 May 2004 by Greg Beatty
Mr. Tibbs -
The inductor and resistor will be in parallel with each other. The inductor's "resistance" is frequency dependent - providing much more resistance to higher frequencies. This means that the low freqs go through the inductor (with low resistance) and the higher freqs go through the resistor and are reduced accordingly. The value of the resistor, relative to the impedance of the speaker, determines how much reduction there is. The value of the inductor determines the frequency that the reduction starts.
Naim have assumed that the walls will provide reinforcement of the bass at and below the baffle step frequency and I have a shoddy-build American home with walls that do not do this. So some correction seems in order. Hope that helps to clarify what I'm attempting to do.
If it turns out for the worst, oh well. It will have been a fun experiment
- GregB
Posted on: 29 May 2004 by Former member
Greg,
Not quite sure where you intend to place your L-R circuit, but if it goes in series between your amp and your crossovers, then you'll lose what treble you already have. It'll sound badly muffled.
If you plan to use an L-R BSC circuit, it needs to be in parallel between the positive and negative output of the filter, but before the impedence correction circuit, which if present, is also in parallel to the driver. Unfortunately, this will all be part of the circuit board that defines the Allae crossover, so you might need to exercise a soldering iron.
Good luck and I'm sure you'll let us know what you find.
James
James -
I'm certainly no expert at this (duh) and am just trying to interpret what I read and improve my hifi a bit
My understanding is that the circuit is a 6db per octave filter that works over a one octave range and then flattens out.
If 8ohm is too much, and I suspect it will be as 8ohm is for a 6db correction, I plan to add a second 8ohm in parallel to reduce the resistance to 4ohm and bring the correction to 3db, which is the measured bass loss I have.
It seems the baffle step correction is doable...even if I have the present implementation wrong. It also seems that the crossover is the place to make the correction and not line-level EQ, although that is another alternative if need be.
I will report back
- GregB
Posted on: 30 May 2004 by Mr.Tibbs
"I'm certainly no expert at this (duh) and am just trying to interpret what I read and improve my hifi a bit"
No nobler a cause... good luck.
Mr Tibbs
Posted on: 03 June 2004 by Greg Beatty
Initial ResultsWell, I had a package waiting for me when I got home from work yesterday and it was the inductors. Getting them wired up with the resistors was a bit of work, owing mainly to being home with my 1-year-old. Always a good time to play with the hifi
But I couldn't wait and managed to get the parts installed. And...
...It works!!!
More bass for sure and, on quick listening, is seems to be coming in at about the right frequency. The volume control needs to go higher to get the same listening level, indicating a drop in efficiency.
More quick listening (with a teething 1-year-old wrapped around my legs) and it sounds a bit thick overall.
With one 8-ohm resistor in the circuit the increase in bass (well, decrease in everything else really) sounds a bit much. This was expected as the Allaes are 6-ohm speakers and an 8-ohm resistor would be expected to give at least 6db of bass boost. I only need 3db of boost. Of course, the speakers are near the room corners, so moving the speakers is an option.
I took measurements using my SPL meter with test tones and verified that the bass was on the warm side, with the speakers in their current position.
So at the last minute of the evening, in goes a second 8-ohm resistor in parallel with the first on each speaker. This reduces the resistance to 4-ohms.
A quick listen and sounds better. And the volume doesn't need to go as high.
This morning I popped in a CD of Dvorak's 9th symphony that I have listened to countless times in the past. In my current setup and room, I have not been able to enjoy this CD. The orchestra is too lean - it just isn't credible.
About 2/3 way into the first movement I realized I didn't want to leave. The balance was better and I was liking it!
Tonight or over the weekend I will try to get a free five minutes to make measurements on the new setup and see where I am.
And about this phase business...
Inductors shift phase by 90 degrees or so and this shift would only be to the 500hz or so and below that are going through the inductor.
How would I measure this? And what, if any, would the sonic penalty be?
- GregB
Posted on: 03 June 2004 by Mr.Tibbs
"More bass for sure and, on quick listening, is seems to be coming in at about the right frequency."
Good to hear things are progressing in the right direction.
"The volume control needs to go higher to get the same listening level, indicating a drop in efficiency."
With this passive attenuator, that's the price you pay for increased bass. Not a problem so long as you've still got enough volume when you want it.
"So at the last minute of the evening, in goes a second 8-ohm resistor in parallel with the first on each speaker. This reduces the resistance to 4-ohms."
This takes me back to changing resistors in the E-III XO's, in search of the perfect balance.
"How would I measure this? And what, if any, would the sonic penalty be?"
James might have some suggestions for you, but if it sounds good, isn't that the bottom line?
Mr Tibbs
Posted on: 03 June 2004 by Former member
Greg,
Which phase are you trying to measure: electrical, impedence or acoustic. The only one that really matters is acoustic, and for that you need measurement tools and software.
James
"James might have some suggestions for you, but if it sounds good, isn't that the bottom line?"
Of course
But I'm still curious...and if there is a way to do the EQ without the phase "penalty", I would be interested. I suspect other makes of speakers have the inductor/resistor in there to correct for baffle step loss and then either are off in the phase area or correct it elsewhere in the crossover.
James - acoustic, I guess. And I guess without the equipment it isn't going to happen. I did find some lab work reported on the 'net that compared theoretical to measured inductor phase shifts. It seems the simple predicted 90 degree shift is often not what is observed.
I wonder, given all the chatter here about Naim bass, if Naim would ever consider offering a baffle step circuit as an option or even as standard with their speakers. The designs assume wall reinforcement that is often not lacking, especially in U.S. homes.
- GregB
Greg,
Naim already offers RCA terminations for their electronics. It won't be too long before they offer free-space designs. It's only a matter of time, and of pride whether they source more suitable bass drivers than their own 8-incher.
James
Posted on: 04 June 2004 by Geoff P
Naim seems to have this love affair with the use of a PAR in quite a few of their speakers, which I presume kids it into changing the box volume to compensate for baffle effects as frequency drops.
In my ignorance I wonder if this would provide some compensation for the baffle step function greg is dealing with here..
I also wonder how accurately they have to tune the resistance of the PAR to get the behavior they want from their speakers up against a wall.
regards
GEOFF
Listening every day planning to "not fade away"
Posted on: 04 June 2004 by Former member
Geoff,
Naim's PAR technique has nothing to do with baffle step compensation. It's a bass driver loading technique that offers the best aspects of acoustic suspension and infinite baffle, but without the penalty of either.
You can read all about it
hereJames
James
Thanks for the correction & the info
regards
GEOFF
Posted on: 04 June 2004 by Greg Beatty
"more suitable bass drivers than their own 8-incher"
Not sure I understand this...the driver is capable of the output...its the crossover that is at issue and how the room boundaries reinforce the speakers' output (or don't in my case).
- GregB
Posted on: 05 June 2004 by Former member
Hmmm. I'm no pro myself, but what you are doing is simply creating a lowpass which I believe will have more negative sideeffects than positive ones.
You are not increasing bass, as I think you figured yourself, but rather cutting of or decreasing other frequencies. In theory that makes not much of a difference. But you are destroying Naims speaker sounding.
Of course, that's fine and up to you, but apart from having changed the essence of the speakers sound, you probably also negativly altered the quality of sound.
By adding this lowpass you are taking away the detail both your speakers and your electronics are known for. You are taking away the clear and sharp treble and upper mids and adding bass. But you are not even adding proper bass but rather the upper bass and lower mids, which makes doesn't even give your Allaes a clean increase in bass.
I myself have Allaes and can't say they lack anything above about 80Hz-100Hz max. So, I think you would have been better off by either adding an EQ or by using an amp with tone control or a psychoaccustic feature such as loudness. Both alter the sounding in a more sofisticated way than just building a simple lowpass and I assume they won't lose more detail than your construction even if they aren't Naim.
Of course yours is the cheapest way and I don't want to sound snobbish or offending, but I think you are taking the typical "sound" and therfor the heart of Naim equipment away and therfor wasting it.
"Not sure I understand this...the driver is capable of the output...its the crossover that is at issue and how the room boundaries reinforce the speakers' output (or don't in my case)."
Greg, what I was getting to was the use of a woofer, and not a mid-woofer. You know, jack of all trades and master of none.
"You are not increasing bass, as I think you figured yourself, but rather cutting of or decreasing other frequencies."
Alex, this is how all loudspeaker designers create their loudspeaker voicing. Tweeters tend to be more efficient than woofers, and hence most need to be padded down. Even Naim's very own.
James
Posted on: 05 June 2004 by Greg Beatty
"Greg, what I was getting to was the use of a woofer, and not a mid-woofer. You know, jack of all trades and master of none."
Ah...well, that would be two-way vs. three-way issue. Naim seem to like two-ways up to the DBL level, at least for now.
Alex - not sure about your comments. I am sensitive to the Naim sound...I am trying to get the Naim sound in my room :-) But Naim's speakers assume boundary reinforcement that I do not have - so I have to compensate somehow.
Also, I am open to low-cost ways to modify the wall behind the speakers. I considered buying a trunkload of bricks and bulding small platforms for the speaker and a backing wall behind each one.
I would prefer not to do the job electrically, but until I find a new wall the choices are: 1) live with thin bass, 2) EQ the speaker either at line level (your suggestion) or at the crossover, or 3) get different speakers. Of course, different speakers may be similar except that they have the baffle step compensation circuit that I have added (!!!) and they wouldn't have the Naim sound.
For me, Naim speakers are not all about having a different frequency response to others, but are about speed and dynamics. My mod does not sacrifice either, provided the resistor is not at too-high a value (8 ohms is too much - I'm running at 5 ohms now and like it).
The circuit is not sophisticated, but simple is fine. Fewer components, fewer connections, and not another box to plug into the mains (such as an EQ). It is a time-honored circuit that I am using, not something made up or whatnot. The references in my first post tell all.
- GregB - enjoying a relatively flat response today
Posted on: 14 June 2004 by Greg Beatty
UpdateNo idea why this was moved to the Padded Cell, but anyway...
After living with "the mod" at 4 ohms for a week, I decided it was just *a bit* plump. So knocked it down to 3 ohms and did the wiring up in a much more secure fashion that provides better contact. Did this Friday and have had it this way over the long weekend.
Also, while doing the better wiring, I took the opportunity to plug the Nait 5 straight back into the Allaes. Had it this way for half a day as I worked on the better mod wiring (again with a 1-year-old in tow) and...
No Way!!! Sounds like the bottom of everything is just missing. Clearly not a case of initially liking the mod and, upon hearing the stock setup, preferring the stock setup. I have had that experience with several tweaks in the past and the stock setup usually wins.
Not this time...well, not in my bass sump room at least.
Popped in the 3-ohm baffle step circuit and Woo Hoo!!! Back in business. And it sounds even better with the improved connections between the components
Sounded just fabulous over the weekend. My wife and I kept digging out old CDs. Much easier to not notice the sound and just enjoy the music. I will re-evaluate in a week or so and see if 2 ohms are worth a go. The bass doesn’t need much of a boost, but it makes a significant difference.
- GregB
Posted on: 15 June 2004 by JohanR
This was done by the ex Swedish Naim importer in a couple of their demo rooms with great result. It works.
And about the phase shift introduced by your inductor and resistor. There will be a phase shift AROUND the working frequency of the circuit. That means that at low frequencies there will be no (or correctly, a very small) phase shift. Around the working frequency there will be a "wiggle" in the phase response, and then at high frequencies it will go back to no phase shift again.
The 90 degree phase shift at higher frequencies mentioned above would be with ONLY an inductor and no resistor parallell to the inductor. It is then a simple 6 dB/octav low pass filter.
JohanR
Posted on: 15 June 2004 by Former member
Greg, would you mind telling me again, how exactly you enhanced your mod? I mean, what could you have done to make it higher quality? Did you build a box, use better cable or what exactly?
And has anybody here treid it? I would, but I haven't really got the time. I'd like to know whether the mod sounds different then the loudness feature or other tone controls? I don't mean quality wise, but when using a non Naim amp with control over bass or an EQ etc. would you say that this simple low pass still sounds better? It can't really...can't imagine so...
It's up and running now!!!
www.ForumPictures.de.vu All new and beautiful!
Posted on: 15 June 2004 by Greg Beatty
Johan -
Thank you for the input on the brick wall idea. I have not abandoned this idea and maybe someday...but not while there is a 1-year-old who could pull the setup down on himself. Glad to hear it works
And thank you for the phase shift info. The working range is supposed to be 1 octave and then the response flattens out again (the highs go through the resistors and avoid the inductor altogether).
Alex -
Better or worst than tone controls or an EQ...I don't know.
The Good Thing is that I have it kicking in at the correct frequency and doing the job with far fewer components than an EQ. The EQ would let you adjust in real time and also adjust the mids and highs to taste. More components and more connections, but I would not claim that my solution is definitly better. I also like avoiding another box in the stack.
(I'm better off not having access to real time adjustments - too tempting!) A tone control on a receiver may be at the right frequency or might not.
And I improved the quality by connecting each comonent more ridgedly and with greater contact area than before. The early setup was twisted together to allow for easy changing of the indcutor and resistor values. Now than I am close, I don't mind doing it up better.
Doing it up better also added a nudge of bass, so I may end up trying 2-ohms after all.
Are you using Subs, BTW?
- Greg
Posted on: 15 June 2004 by Mr.Tibbs
Does any talk of modifying get chucked into the cell now?
Mr Tibbs
I do use Subs. But they cut off at 36Hz so there is hardly any overlapping.
I don't need them all the time, only for poorer recordings. But you can't hear them so I guess they are fast and therfor good enough to play with my Allae. They just add a notch of bass.
But I do use the loudness function. Sad but true. But then, where's the point of using great equipment like Naim, if you can't listen to your crappy favourite albums any more. I didn't record them and now I have to live with them or alter the sound to my likings. I'm going to demo a Nait 5i & CD 5i today and probably try to arrange a home demo for next week. Let's see how it compares to my cheap Technics CD-Changer and my truly great Pioneer AVR.
Posted on: 16 June 2004 by Greg Beatty
Let us know how you get on with your auditions.
FWIW, a power supply on a Naim CD player increases the "Omph" factor quite a bit. I would not consider the CD 5i for the reason that it cannot accept an external power supply (as you no doubt well know).
I am running a Nait 5 with FC2 and my DVD player has a reasonable quantity of bass - not nearly as well controlled as the CD5 (which I have auditioned in this system), but the quantity is close.
- GregB
