Where to buy car tyres
Posted by: MontyW on 26 October 2004
Can anyone recommend the cheapest place to buy car tyres and also get them fitted? Also, has anyone had any experience of Black Circles the online tyre company?
Dave
Posted on: 26 October 2004 by John Sheridan
I used Blackcircles for my last purchase as they were the cheapest option. You select your tyres and they refer you to a local shop to have them fitted.
Posted on: 27 October 2004 by Jimmy Jazz
Try A&M tyres in Pemberton (near Wigan) ask for Tony. Alternatively SMD tyres at Leigh just off the East Lancs Rd.
Posted on: 27 October 2004 by HTK
I've found that getting tyres is like nenewing insurance. Ring round for the best quote and nail them to it. Tomorrow you'll get a different set of numbers.
Harry
Posted on: 27 October 2004 by quickie
Mytyres is even cheaper than Blackcircles....
http://www.mytyres.co.uk/start.html
Posted on: 27 October 2004 by John Sheridan
yes they're cheaper but their prices don't include fitting.
Posted on: 27 October 2004 by MontyW
Thanks for the messages - it's amazing the difference in prices! So far Blackcircles are the cheapest including fitting and are approx' £50 cheaper (for 4 tyres) than most other places.
Posted on: 27 October 2004 by Don Atkinson
David,
No good to you in Manchester, BUT
for anybody nearish to Newbury, HEADLEY TYRES LTD.
I have just checked two sizes that I have bought in the past 3 months, both Michelin
155/70/R13 75T
205/65/R15 94V
The smaller ones just over £5 cheaper and the larger just under £10 cheaper each.
Don't know how ATS/KwikFit etc survive hereabouts!!!
Don
Posted on: 27 October 2004 by Derek Wright
If we are going to expand the potential area - I would contact Micheldever tyres first and then see if the local firms will compete in price - allowing for the 60 mile roundtrip for me.
Micheldever Tyres
Derek
Posted on: 27 October 2004 by long-time-dead
1. Find the cheapest online service that offers local fitting.
2. Get a small local tyre service to see if they can match or better it.
3. Go to Kwik-Fit (or similar) who offers price-matching to your local fitter as standard.
4. Go back to the local dealer and give him the business if he can come down a couple of quid over Kwik-Fit.
