stupid q's for recording records to MP3
Posted by: Two-Sheds on 13 November 2004
so I've been here for a while and I haven't asked (I don't think) any really stupid/simple questions so here goes.
I want to record some of my records on my pc to use on my iPod. The first problem is connecting the pc my pre amp (NAC202). the input on my pc is a 3.5mm stereo jack and I have a cable from 3.5mm jack to 2 phono plugs, but I assume I then need an adapter to plug it into the tape input on the NAC202 or is there any way I can configure the aux1 or 2 phono sockets to be outputs?
Once I get it all hooked up is the output to the tape always on? and what is all this tape monitor circuit buisness? do you have to use it whilst recording? does it improve sound quality of the recording?
finally anyone know any good (free if possible) software for encoding sound input to mp3 and does it allow you to before/after/both split up the recording into tracks?
