Remote Control Problem with NAC82
Posted by: Adrian F. on 20 October 2000
Hi everyone!
Music sounds good as usual, but the balance does not react on remote signals.
Everything else works remotely (volume, mute, mono, inputs).
I switched the Super-Cap off and plugged the NAPSC out for about 15 minutes to do a "full reset", but nothing changed...
Is there anything inside, that I can check/fix myself, before rushing out for service (something like a loose cable plug to the balance motor).
Thanks for your ideas!
happy listening
Adrian
Posted on: 20 October 2000 by davidf
try a new battery
Posted on: 20 October 2000 by Adrian F.
but no. (it would have been the cheapest failiure)
I've got 3 remotes:
one from NAC82
one from CDSII
one programmable/learning type
with every remote, every other function but this da.. balance works!
My dealer suspected a pushed in balance button, which makes contact to the front-plate of the 82 with too much resistance for the motor to turn - but it's not the case.
I can hear the motor of the volume button when remote controlled, but the balance motor keeps quiet. Soooo:
1. the signal does not get from the IR receiver to the balance motor
2. this is a late motor, it's gone to see its maker, this motor is no more,...
...and now to something completely different!
happy listening
Adriang
[This message was edited by Adrian Frauchiger on FRIDAY 20 October 2000 at 15:08.]
Posted on: 20 October 2000 by Rico
What's the S/N range of your 82, out of interest? (eg 137xxx)
Rico - musichead
Hi Rico
Ooops, I'm in the office right now and don't know it by heart - but it's about 8 years old.
No other problems in all this time and all those power supplys.
happy listening
Adrian
