Linking comments in Word
Posted by: Mekon on 22 June 2004
I want to link comments I've inserted in sections of one document to comments I've inserted in another document. Is it possible?
Posted on: 22 June 2004 by stevie d
Yes it is possible....
Step 1. If the word/ paragraph you want to link to page one is in page 3, go to the word in page 3 then select INSERTfrom the menu and then bookmark then give the link a name.
Step 2, Go to where you would like the link to go and again select Insertfrom the menu, then select Hyperlink. Where it says named location in file click browse and then select the link required. If the info is in another document click on link to file/URL and find the document required.
If this does not work, PT me and I can give you a call over the phone if you like.
Good luck
Steve
Posted on: 22 June 2004 by Mekon
PM sent
Actually try this....
Instead of the book mark option click here and select the document you wish to link to the parent document and that should work. If not then give me a call
Steve
[This message was edited by stevie d on Tue 22 June 2004 at 13:50.]
