112 /150/SBL's vs 102/180/Credo's which is the better combination?
Posted by: Le Chef on 25 October 2000
I'm trying to figure the right heirarchy. btw. Front end is LP12/Lingo/Aro/Troika.
Also are the 112/150's in half-width or full width cases?
If you don't know the answers, could you point me in the right direction?
Many thanks for your help.
Le Chef
[This message was edited by Le Chef on THURSDAY 26 October 2000 at 17:36.]
Posted on: 27 October 2000 by Former member
HI, personally I prefer the nac102 and nap180 combination which is a very good solution. The new 5 series is exactly like the slimline so it's 58mm height and the height of the other devices is 76mm.
I heard last week the cd5 with the nait5 and after the same cd5 with the nait3r on an intro pair of loudspeakers and frankly... these devices works so good together. I prefer the new cd5 with the nait5 than the cd3.5 with the nait3r but these sounds very well indeed ! :-)
Maybe I want to try a nac112 with two nap150 in a passive bi-amplification configuration... I don't know.
If you choose the nac102 and nap180 amp line, I recommend to put the cdx with it ! god ! this is music :-)
...then upgrade for a hi-cap (or super cap) to power the nac102 and cdx.
frankly, I'm pretty sure that a system built on a nac102/nap180, hicap and cdx is a great system with a great value. And of course and great sound !!!
cheers, ERIC
Eric,
You currently do not own a Naim system but it's on its way. Could I say that Naim (Linn too) + Liège = PDV de la GdS.
