Naim EQ
Posted by: garyi on 06 May 2004
Naim EQ?
Guys I am experimenting to make the most of a mediocre sound I am getting from my mac into an arcam dac.
Now don't laugh and bearing in mind I will get another CDplayer in the future is there any way of knowing how naim sound is crafted?
Do they for instance have a form of EQ they want to achieve when designing Kit and how best could I set an EQ on the mac to best emulate the sound I enjoy, or at least improve the sound to a reasonable level whilst I wait to purchase another CDPlayer.
Right now the sound can be harsh, (I am actually worried about my tweeters). I appreciate the file sizes are half what they used to be so basically I am trying to polish a turd but improvements can be made with a bit of tweaking in the short term perhaps.
Any ideas?
Posted on: 06 May 2004 by o.j.
Hy garyi!Do not know how cd sound by naim is done,but i would look to the threads about "dither".normal equalizer can bring you only to better tonality.the other part of sound
is your mac cd "transport".
So iwould say decide between:equalizer(cheap) in your soundcard and naim cd (best).
O.J.
Posted on: 06 May 2004 by Greg Beatty
Garyi -
Have you tried an iPod instead of the Mac itself?
- GregB
Insert Witty Signature Line Here
Posted on: 06 May 2004 by Thomas K
Gary, don't tell anyone, but you can get a "plug-in" from www.keepondreamin.com that'll make your "computer" sound like a proper Naim "sistem".
BTW, I heard an iPod docked into a dedicated station by Altec Lansing the other day -- thought it sounded fabulous for what it was (could have been because someone had just poked lots of needles in my skin, though).
Thomas
Posted on: 06 May 2004 by David Dever
Which Arcam DAC are you using with the Macintosh - and by what method is the signal travelling to the DAC?
The audio hardware (and its driver, under whatever OS you're using) will also make a difference, especially as noted earlier WRT dither and playback buffer settings.
(I gather that you're using iTunes, or something else?)
Posted on: 06 May 2004 by garyi
Out put the G5 via optical toslink, into a Arcam Crap Box 3 then into the hifi.
Yes I am using itunes.
Posted on: 06 May 2004 by graphoman
that’s what I would not risk. But I only have G3sSmile
graphoman
