leather suite cleaner
Posted by: jason.g on 16 June 2004
i think this has been asked before. i have a leather suite which need cleaning regularly (new vomiting baby). i bought some spray stuff from bettaware which does the job but someone said that you should also use a product that moisturises the leather. is there such a product that does this, and if so, how often should it be moisturised?
what were barn owls called before barns were invented?
Posted on: 16 June 2004 by ARC
I used sadle soap on the leather in my car and it was very effective, hard work though.
Brendan
Posted on: 17 June 2004 by Hawk
there some stuff called tula cream which can be bought from john lewis, it did a great job of getting my 4 year olds artistic efforts off my leather car seats! Im not certain without checking but i think it does the moisture thang too!?
Posted on: 18 June 2004 by jason.g
how long does it take for these products to soak in/dry? i notice that when i wipe the sofa, some brown dye comes out each time. it was an expensive suite from house of fraser aswell.
Posted on: 18 June 2004 by count.d
Jason,
The best way to clean leather is with a damp cloth with no detergent.
You should follow up the cleaning with the best leather wax/oil, which is Mars Leather Food. Not preserver, oil or wax, but called Food. You can buy it online. This will soak in within 24 hours.
Posted on: 19 June 2004 by DIL
Neats Foot Oil. Works for me.
/dl
