72 + 140 vs 72 + hicap + 140
Posted by: louis_lx on 18 January 2001
It sounds like you upgraded the power amp for one. MUCH deeper, tighter, and groovier bass. Much warmer, more palpable, room filling type sound. Better treble extension, much less harshness. MUCH better dynamics. And more detail. A no-brainer.
--Eric
1) Go to your dealer, bringing some favorite music.
2)Have the dealer demo with the hicap.
3)Listen for several minutes.
4)Have the dealer remove the hicap.
5)Listen to the same music through the same preamp.
Taking away the hicap is like someone taking away your pet.
Don't do this unless you can afford a hicap.
BTW, on good sources, the 72 is excellent, and adding a hicap to a 72 playing good source never gave me an understanding of what the hicap does. It's only when the hicap is taken away that it's importance is clear, IMO.
On normal - i.e. mediocre - source, the hicap makes the 72 wonderful. I hate to listen to normal sources through a bare 72.
Differences? Much less congestion in loud, complex passages, much more coherent sound, much better bass and detail and real-ness.
Regards.
Phil
Arie
BTW, a regular SNAPS is about 75% of a Flat-Cap, but a SNAPS2 converted to dual rail mode is a touch better than a Flat-Cap. Therefore, if you can't afford a Hi-Cap, then find yourself an old SNAPS2 and get it converted (if it isn't already). Catch you later!
-=> Mike Hanson <=-
You 'caused to my affairs with the 72 so you have a responsibility.
What do you think about Mr Pig opinion that getting a Mana instead of a Hi (the Mana is cheaper) is a better value ?
Arie
Since much of what an XPS does for a CDX involves detail and resolution, I'm considering getting a Mana rack for my system before an XPS for my CDX. However, I would definitely upgrade from a Flat-Cap to a Hi-Cap on a pre-amp before getting Mana. It really transforms a pre-amp.
I wasn't "satisfied" with my Naim system until there was a Hi-Cap on my 102. All of the upgrades since then have been gravy. Catch you later!
-=> Mike Hanson <=-
Mana helps define and tighten, which is a very good thing. However, Mana is not a cure-all. There are many things that must be achieved through other means. Catch you later!
-=> Mike Hanson <=-
How is the sound at your new house ?
Arie
The room they're going into is fairly small (12.5'x9' or 3.8x2.75m). There's also a closet (2'x4') in one corner, so it's going to be a little strange. It's shaped somewhat like this:
code:
WWWWW
| S S |
| EE|
| EE|
D --+
D M C|
+-FFFFF---+
This picture is not entirely to scale, but it gives you the idea. I've shown the first configuration I'm going to try. The speakers (S) are aiming down the room, with a bay window (W) behind them. I'm sitting (M) with my back to the french doors (F), with another door (D) to my left. The equipment (E) will be will be placed as shown, and there's a CD storage cabinet (C) in the closet (with the doors removed). I'll probably place sound absorbant material against the outside wall of the closet (beside the equipment), to prevent extra reflections.
In the end, if I can't make it sound good in this room, I can always try it somewhere else. This room is preferred, though, for a number of reasons. Catch you later!
-=> Mike Hanson <=-
symetric.
Arie
-=> Mike Hanson <=-
Arie
A real good place to start is by making sure that all floorboards are VERY securley screwed down.
Preferably using brass screws (...overtures of the "non-ferrous" brigade appearing)
...Looking forward to when you eventually move in for all the "wooden room" follow up posts !
(I am sure that there is no need to fret...I bet it will sound just great !)
Chris
-=> Mike Hanson <=-
I should stress that the dolls are the former owners, and not mine!!! (The whole house is decked out in that kind of trash.) Instead, I'm considering placing a large statue of a neanderthal fellow with genetalia on full display. He's holding a sword in one hand and the head of his recently vanquished oponent in the other, so it's really very exciting.
-=> Mike Hanson <=-
I also hope he will not be able to see the modern life out of the window - it may confuse him.
Arie
BTW, I just noticed that the floor in that picture is almost black. It's actually a dark brown, and is quite nice. Catch you later!
-=> Mike Hanson <=-
From snaps to hicap was more like "ooh, it's much tighter sounding all around, with another layer of detail." Of the two, the snaps was more important in getting a satisfying sound, and cheaper too. That said, I think the 50% of a hicap assessment of Mike H. is about right in hi-fi terms, it's just that the first 50% is cake, and the second 50% is icing.
--Eri
arie
