Board Pulling on 72
Posted by: Simon Jenkins on 31 August 2000
I have read in various places that you can get big sound improvements by pulling the unused boards on a 72. As I currently only use the phono, and soon cd, inputs is this worth doing?
What benefits should I expect to hear.
Also, would removing the boards invalidate my warranty ? The 72 is less than 6 months old,it was replaced earlier this year after a break-in, so there is still 18 months or so left to run. My last 72 ran fine for 5 years plus, so I'm not to concerned about it breaking down, but would be interested to know.
Simon
Posted on: 31 August 2000 by Former member
It's a simple job and should have no warranty problems. Just undo the 4 feet, slide the chassis out and pull out the 2 phono boards (nearest the BNC inputs (number NA323 K/S Phono MC or
NA322 MM Phono). Generally results in a cleaning up of the sound - mine has the tape boards (NA324)pulled out as well. I've also added extra regulation to the remaining boards with excellent results but that's another story....
james.
Pulling the phono boards certainly will clean up the sound as he'll nothing but silence from his turntable! ;-)
I run my CD player through the second pair of BNC's on my 72 and bypassed the high level link boards by removing them and re-soldering the wires from the "input" side of the pins to the "output" side negating the use of the boards and effectively removing un-needed connections.
The result was quite pleasing.
Paul
Posted on: 31 August 2000 by Simon Jenkins
Thought perhaps my original post was a bit vague. I am not replacing my vinyl source with CD, the CD is in addition. So the removed boards would be the tuner and the two tape circuits.
Simon
Posted on: 31 August 2000 by Greg Beatty
Here is a complete 72 board rundown, copied from the old forum. The tape-out boards are the ones you will want to pull.
Here goes:-
325 Switching relay, Switch-on output delay
321 Main Gain, Output Drive times 2
324 Input Buffers and Tape output Buffers times 4. These output boards are one for left channel, one for right. You can't just use one of them when you record.
729 Time-aligned input buffer boards
322 MM Cartridge times 2
323 S / K MC cartridge boards times 2
326 Link Boards for connecting high level sources
328 As above, but with variable sensitivity option; also has high frequency filtering.
The spare four pins are for the Aux / CD input. You should plug your cd player here for best results. Try your cd through the Aux socket. If you get no sound, then you will need to get the 326 link boards. I think the tuner input is going to be almost identical in sound quality.
Hope this helps.
Paul Desmond
Naim Audio
Whoops didn't notice a turntable was being used ...
Posted on: 13 September 2000 by Simon Jenkins
Finally got round to pulling the boards on my 72 last night. Was only able to remove the tape boards, but even this made a difference.
I found that the improvements were subtle, slightly tighter bass, improved clarity.
To compare, I found the improvement to probably be about half of what I got in going from some old QED79 strand speaker cable to NACA5.
Subtle changes, but definatly worth doing.
Simon
