question to 135 owners
Posted by: Uwe Supper on 14 September 2000
I am more than sure that the topic has been covered in the old forum, but at that time I couldn't be bothered. I own now a pair of 135s, and the sound is phantastic, however what worries me a bit is the (slight) hum from the amps. I know, question of the mains, and it is nothing that prevents me from enjoying the music, but being a perfectionist, I was just wondering whether there are any other solutions you might have tried out and which could solve the problem.
At present the system is (from the top): 135, Supercap, 135, CD2, 82. Any comments are welcome. BTW, when the dealer installed them, the hum wasn't noticable, and as I was saying, it is not a big problem. Does anybody stack them?
Thanks in advance for your input.
Uwe
Hey, good on you.
The 135 is one of Naim's finest.
Vik.
Rico - musichead
I've had 135's for some years, and like any Naim product with a big toroidal transformer; they will hum if there is distortion of your mains supply. Installing a spur will not necessarily cure it. I know because I've done it. It is still worth doing, however for improved sound quality. Naim's hard line advice used to be "Put them in a cupboard". However; I think I'm right in saying that Naim do now endeavour to make new transformers quieter. Compliant mounting has been tried, but it degrades the sound. My local H.V. grid was overhauled recently, and it did bring about a great improvement in reducing the buzz. You are basically at the mercy of your local electricity supply. Presumably you've tried turning off everything else in the house? If the buzz persists; don't get excited about a separate spur curing it because it won't.
Aren't 135s great? Needed mine to keep Dynaudio Contour 1.8s under control.
My 135s are about 5 years old and vertically stacked, with a Hicap on top. CDX / NAT03/ 102 stacked top to bottom next to them. There is a slight hum which I've been unable to remove but it's not troublesome. Certainly disappears when the music is on.
I don't have a dedicated spur and the hum is constant throughout the day, so not related to peaks in electricity use.
I live with it but am open to suggestions on getting rid of it.
Graeme
Thanks so far for the input.
Uwe
just to be complete: there is also a pair of (used) Shahinian Obelisks now in the system, a Audio Counsel 6-way-block and the mod on the 82 which has been mentioned in another thread.
No wonder, the neighbours start complaining ...
Uwe
Andy
I have pair of 135 amp. There are made in 1992, one recapped in 1999 and the other not recapped. When I open 135's, Recapped 135 is changed current spec. main transformer.
Current spec. main transformer have more hum.
I don't know why occur more hum from current spec. transformer.
I think early main transformer have less hum(it's made in Holden & Fisher TX).
Regards.
Um
Tony
nice to read you. AsI was saying, not a big deal, I think it is only one of them, and the buzz varies according day time. As soon as the music is on, it is gone.
When do you intend to sell your NAP 500 (blink, blink)? -:)
Uwe
This is nonsense Um and you have no reliable experience to back up your statement, how many other 135's of different spec have you been able to compare?
None.
You have a pair of amps which aren't even matched. The one with the newer transformer may not even have been updated properly, you don't know who did the work (it wasn't us) nor whether the components were supplied and/or selected by Naim.
It may just be coincidence that one xformer buzzes
more than the other, but it may also be that you have sub-standard amplifiers which have been poorly maintained or messed around with by someone unqualifed.
would you so kind as to mail me privately, all the questions I have are probably of no interest to the usual public. Thanks in advance.
Uwe
