Who has crowns - need advice
Posted by: Justin on 17 June 2004
Well, yesterday I had a new set of pedals put on my new bike and I went outside to give them a spin at my local bike shop. The blacktop was wet and I wiped hard and ate asphalt. Scratched my left shifter/brake lever (not to bad) a few cuts and welts. The biggest hurt, though, is that I chipped the begusus out of one of my top front teeth. It have a huge horizontal crack about 1/3 of the way up the tooth, though, mercifully the bit has not broken off (despite some signifcant pushing by my dentist).
Anyway, he says it WILL break off - it is just a matter of time, and in any event the crack will stain and I will be back in his chair in no time for a crown. In fact, he says with the two front teeth two crowns is better than one because it is hard to match 100% to the other incisor. But matching to the other teeth is easy.
Anyway, does aybody here have a crown on thier front teeth. What is the "pain" and "yuk" factor of the procedure. How do you like the results, and what kind of material did you get?
Yesterday was a VERY crummy day.
judd
judd
