Before I delve into this question, I know that a lot of the answers will include comments such as 'go and listen and see', but that is not always possible so.....
Currently I have the following Naim settup:
CD 3.5/FlatCap/102/HiCap/Napsc/180/SBL's
And I wish to upgrade, but the question is via which route. After having a CDX on loan over Christmas, I am clearly aware of what difference swapping my source for a CDX can make, but another side of me says that I should try and get the most out of what I have already got before I go any further.
Therefore, should I sell the CD3.5/Flatcap, and go for a CDX as a source, or should I - for what will be a lesser outlay, replace my SoundOrganisation Z650? rack for one of a more suitable pedigree.
With the system as described above, a 5 tier Mana amp support would be the minimum, to which I could upgrade once funds allow, referencing, and soundstaging.
My current thoughts on the system as it stands are:
- Doesnt have the depth of information the CDX had, and the base information came across far betther than the CD3.5/Flatcap did.
- I have run the system as follow as an alternative, and had some interesting result: CD3.5/HiCap/102/FlatCap/Napsc/SBL's - This certainly got more out of the CD3.5 but to the cost of the 102.
- I, as many have, have found the 102 a little harsh compared to an 82 (thanks Russ for the loan) and will at some point go to an 82 as funds/availablity allows. Will the Mana Amp Rack (initialy on its own) improve the CD3.5 and/or the 102 to enable me to postpone the purchase of the CDX or the 82.
The system is housed in a 4x3.5mtr room, wooden floors (with a little give) and are powered via a dedicated spur, but no dedicated earth (to be done once the pathway is replaced.
Any comments would be more than welcome.
Posted on: 15 January 2001 by ken c
steve: what equipment supports are you sing right now? if at all possible, i would improve the front end of your system first. i suspect the sbl's are revealing weaknesses upstream. i am assuming of course that the minimum pre-amp for sbl's is an 82. this assumption may be incorrect. check with your dealer, or naim. if the pre-amp is deemed OK, then i would go the cdx route straightaway.
then when you get your mana, it will bring out the best in the cd player.
of course, if supports are higher up the hierarchy than pre-amp, then of course, get the mana first. i really doubt this is the case though.
enjoy...
ken
Posted on: 15 January 2001 by David Dever
Steve-
You should (or could) do both--but each in its proper turn.
Ultimately, you'll find that a separate Reference Table (should you choose to accept this task) for a top-notch source makes more sense than spending an equivalent amount to fit all of your equipment onto one rack, with entry-level source and mid-range amplification / speakers.
Something about a standalone Reference Table "breathes" better, than a two-tier table with the same height....it's just difficult to describe.
That said, I've never seen a Mana table with a swing-arm laser.
No, seriously, you'll find it much easier to set an arbitrary spending limit on "black boxes" (to use the token Mana coinage) if you've balanced the system reasonably well front to back; improvements made in the supports area will be better distributed throughout the entire system when you've got a good source.
Hope this makes sense.
Dave Dever, NANA
Posted on: 16 January 2001 by Steve Hall
Many thanks to all those who have responded, a few comments:
Jean-Christophe - I have contemplated getting a used LP12 and over time increasing its specification with Arm/PSU/etc, but as I'm of the CD generation it would mean an investment in media as i've 10 times as many CD's as LP's. - Its a back burner idea at the moment, but you are very correct!
Paul - I have heared both a CDX and an 82 in my system and I agree with you wholeheartedly. I have heared before the CD Player may be the heart of the system, but the Pre-amp is the soul, in my system a heart transplant gives better improvement than a soul transplant! Both is also better
David - Yes it did make sense
Both DO need doing, and it is down to a return on investment decision. I will hopefully this year be getting a CDX, but I have the option of swapping the stands now. I have also seen a used reference table, so I might consider that route too and later replace the SO stand with a 4 tier amp stand, which reduces my initial outlay quiet a lot.
Juan - Interesting idea, and no cost! Do you mean the whole system, or source, or source/pre-amp?
So many decisions, so little money
