DVD Writers
Posted by: long-time-dead on 15 September 2004
Having just discovered YET another scratched DVD in my children's collection, I have decided to buy a DVD writer to add to my PC.
I intend to use it to make copies of their disks for use with the (unscratched) originals stored.
Any recommendations / pitfalls ?
Posted on: 15 September 2004 by Jez Quigley
There is lobbying going on all over the world by Hollywood to make it a criminal offence to do what you suggest. Go to www.afterdawn.com to read their news/links. In the USA they are trying to make it a criminal offence for anyone to even suggest how you might make a backup copy, or point to tools which can do it.
So if for example, I was a USA resident, and suggested that you visited www.doom9.net and downloaded 'DVD Shrink' I could be jailed. But of course I would never do such a thing, so each time your kids scratch your DVDs you will have to stop their pocket money and buy another one.
However, assuming that you want a DVD writer for legitimate purposes I strongly recommend the NEC ND 3500 available from www.cclcomputers.co.uk and elsewhere for around £62. It is the fastest DVD writer that I am aware of and can write to the double layer (8.5 gig)discs just starting to appear on the market. As you would expect it can write to the 'normal' DVD+R, DVD-R discs and CD formats too.
Posted on: 16 September 2004 by Paul Hutchings
Ditto on the NEC.
cheers,
Paul
cheers,
Paul
Posted on: 16 September 2004 by long-time-dead
Jez, Paul
Thanks for the advice - it will be purchased and installed.
Why can't the bl**dy DVD makers use a better quality of plastic to make them more resiliant to scratches ?
PS: Jez - my intentions are moral. I would never dream of visiting such sites as www.cdcovers.cc
Posted on: 16 September 2004 by Jez Quigley
I refer the honorable gentleman to the answer I gave earlier
In fact it's not usually the scratch itself (unless it's really bad), but the muck that gets into the scratch and deflects the laser. A good clean will recover most. Unfortunately DVD blanks are even easier to scratch than the commercial ones.
Posted on: 17 September 2004 by long-time-dead
NEC bought this afternoon at my local supplier. It comes recommended to me by them also.
Picked up some Verbatim 4x DVD blanks too. Any preferences to blanks ?
Posted on: 17 September 2004 by garyi
CD covers is a bunch of crap now, they got caught basically
....and that is why I would never dream of using them......
Posted on: 17 September 2004 by Jez Quigley
The blanks made by Ritek are my choice, they are widely available mostly hiding behind other firms brands.
You can check the disc manufacturer (and a few other details) with DVD Identifier
Posted on: 17 September 2004 by Andrew L. Weekes
Re: Blanks.
These guys are good and do a whole range of Ritek dye discs; these seem to give best results and widest compatibility.
http://www.blankdiscshop.co.uk/
Andy.
Andy.
Posted on: 18 September 2004 by Jez Quigley
Andrew,
Good prices and I like how they give the dye type as well as the brand.
They also sell TDK 'scratch-proof' blanks that may be of interest to long-time.
Posted on: 27 September 2004 by Jez Quigley
An update on the NEC 3500.
When you get to trying out the dual layer discs the Verbatim brand should work ok. However you might have problems with the Ritek dual layer blanks (also sold as Traxdata DVD+RDL). I have a firmware update for the NEC 3500 that I can email you if you need it.
Posted on: 27 September 2004 by Stuart M
Before they wen't bust I got a copy of DVD Rescue from 321Studios (with the ripper), so far it's let me mrescue several DVD's that were copies and (although it took 12 hours) one with a 2cm crack in it!
Posted on: 29 September 2004 by pingu
Posted on: 29 September 2004 by Martin Payne
Jez,
can you e-mail it to me, too?
What does it fix/improve?
cheers, Martin
E-mail:- MartinPayne (at) Dial.Pipex.com. Put "Naim" in the title.
Posted on: 30 September 2004 by Jez Quigley
ok Martin, it's on its way.
It enables the NEC 3500 to write to Ritek dual layer blanks (at present only Verbatim dual layers are officially supported). I've used it successfully for a few days now. It also allows writing at 4x if the blanks are capable of it even if it says 2.4x on the label. NEC says they will release an official firmware update that will support other dual layer blanks but they don't seem to be in any hurry. In the meantime this unofficial update works just fine and is a total breeze to install, but I must stress that you use it at your own risk as it will invalidate your warranty and could potentially stop your drive working altogether. I'd suggest you backup/get a copy of the current firmware from the NEC site to reinstall just in case, alternatively stick with Verbatim discs until the official update comes out. Having covered my arse, I have to say I had absolutely no problem with it. Just run the file, wait till it has finished, and then reboot the PC so that Windows can detect the 'new' drive.
The file is 1mb so I hope you are on broadband!
Also your email client (Outlook?) might not like it as it is an executable.
[This message was edited by Jez Quigley on Thu 30 September 2004 at 16:24.]
Bugger, your email service thinks it is the netsky virus and won't deliver it. I'll try a different way. Do you have an unzipper for .ace compressed files? I could try that.
Martin, I tried sending it as a compressed .ace file, but pipex says your mailbox is full! Let me know when you want me to try again.
I've virus scanned it just to be sure and it is clean.
At the risk of ending up like Berlin Fritz and talking to myself, here's more. I've had a look on the NEC website and there is still no sign of the official firmware update, but I did learn that the NEC3500 will burn Verbatim 2.4x at 4x with the original firmware.
Posted on: 02 October 2004 by Rick Weldon
just sold a guy two! MAX servers each one holds 900 uncompresed dvd's £45,000 each!!
Posted on: 03 October 2004 by Martin Payne
Jez,
sorry for the hassle.
I've got a copy of WinACE, and I've now cleared some space in my mailbox (again!)
Thanks for your attempts.
cheers, Martin
Posted on: 03 October 2004 by Jez Quigley
Ok, I'll try it again.
Posted on: 04 October 2004 by Martin Payne
Thanks, it has arrived.
Much appreciated.
cheers, Martin
Much appreciated.
cheers, Martin
Posted on: 04 October 2004 by Jez Quigley
Let me know how you get on. I've tried 2 flavours of Ritek discs now with no problem (except the price - £4.xx , jeez).
For info - anyone passing through Leeds check out the stall in the covered market. They have a massive choice of CD/DVD blanks at =< internet prices.
