soft cloth and solution that is used to clean monitor (computer) screen.
Posted on: 27 April 2004 by Steve O
I was told just to dust the fascia regularly with a two inch paintbrush.
Posted on: 27 April 2004 by Winnie
Small quantity of Astonish Glass and Tile cleaner on a tight sponge (not the type you wash the car with!). This is what NAIM HQ use. It can be purchased from http://www.astonishcleaners.com.
