Active Or Not
Posted by: MontyW on 21 November 2000
Dave
Going active in the context of your system can improve certain aspects such as loudness, clarity and dynamic shadings. However, these could also show up deficiencies in your source components and create a result that is less desirable overall.
Although Naim has built the IXO espressly for their entry-level systems, their over-riding philosophy is that going active effectively requires the best electronics up front. By this, I mean CDS2 or full-monty TT, and 52/Supercap/snaxo/250s.
In your situation, you'd find better result in upgrading your source components, e.g. finding an Armageddon PSU for your LP12, upgrading to CD2/CDX, and perhaps a better cartridge. Or alternatively if your are perfectly satisfied with your current system, buy lots of music with your spare change.
James
I'm writing to mention that while Linn considers the Ttable drive to be more important that the arm, Naim does not. The ARO should come before the 'geddon. If you prefer the Ekos, the Lingo should come first.
The ARO is a fantastic buy.
Regards.
Phil
I was in the same position as you except with Karik CD front end. Yes, the source does come first but you have to consider the sound per pound ratio. You say that you can pick up the combo for £500 so I would advise that you go for it. Going active in the context of a 92/90 system will bring a noticeable improvement in clarity, timbre and communication. Like all upgrades it will show up problems elsewhere, like poor setup so have a good tidy up in that respect. I keep the pre-amp away from everything else but the rest just sit on top of one another. You don't see many people on the forum talking about thier active 92/90 systems, probably because they feel somehow inferior to the 52/250 owners but I believe that the 92/90 system is great for the money and for me going active made me satisfied with the sound for the first time in my life. I haven't got thousands of pounds to blow on hi-fi so the slimline range was something I could build on bit by bit and I think that not enough people have heard what the little 90's can do when activated. The sound isn't perfect and I'm sure that adding an 82 pre-amp would give a substantial lift to the sound quality but I haven't seen any for £500.
All the best.
I found after a demo consisting of various cdx, xps, 3.5, ixo variations the ixo option was by far the best. In the end I ditched the cdx option and went for the ixo, but in hindsight the snaxo 2-4/hicap would have been a better long-term solution (price wise) but the ixo was nearly a third of the cost.
I have heard a single 250 in basically my setup, yes it had more 'weighty-control' but had nowhere near the dynamics of the active option, the improvement was obvious (to me).
I think the ixo is a naim 'great-faliure', great in terms of its sonic abilities, and failure in terms of a misunderstood/overlooked nugget.
Some 'crazy' people are selling ixo's for £300 (BARGAIN), my advice dave if you have no aspiring full-on naim plans and you like your system (aesthetically it'll look good – all slimline series) then hawk the Loot and DO IT
naheed...
Alternatively you could scan the ads for a second hand Naim tuner a decent aerial (an 03 or 02).
regards
Dev
You have a well-balanced system, so spend all your money on LPs and CDs...something you will never regret doing.
Hock ![]()
While Naheed's observations above are valid, it must be noted that many who have embarked on a "mullet" upgrade path enter also into an upgrading spiral (an uphill one, at that)... each upgrade exposes the limitations of the chain preceeding it, prompting another upgrade.... until you finally end up with a CDSII in your system, with a large credit bill.
Just like a visit to Frank Lloyd Wright's Guggenheim Museum in NYC - Start at the Top .
Rico - musichead
naheed...
Rico - musichead
naheed...
The IXO and NAP 90 are on their way to a new 'happier' home.
Wow! Well come on man, spill the beans! Where is your system going now, and don't forget to mention the black-shiny supports!
We're keen to hear of your dem/experiments/discoveries. Have you traded that kit for more source, more mana, more music; or did a), or b), give you more c) anyway?!
Rico - musichead
But my shiny black tables are working a treat the cds2 is on hold. So it'll be more tables (P7) and loads of music at the moment.
With the shiny black tables, i now buy around 6-9 cd's a month compared to the 1-2 previously. Its exactly what i want from my system (musical enjoyment).
naheed...
[This message was edited by Naheed on FRIDAY 24 November 2000 at 13:40.]
