New digital camera - advice please
Posted by: JonR on 28 May 2004
Guys,
I'm interested in buying a digital camera, one that's reasonably good quality and fairly inexpensive. I'm not a serious photographer by any stretch of the imagination so it would not be used that frequently. I've got an 'outline' budget of about £100.
Having said that I've just seen an offer today for the Olympus D395 (spec: 3.2m pixels, 4 x digital zoom, 1.8" LCD screen, 16Mb memory card) for £120, which is £50 off the original price. About £20 above my budget but the spec probably covers everything I will ever need and if it's worth it I'll buy it.
So, does anyone have any experience with this camera, or a similar model or with Olympus digital cameras in general? Or can anyone recommend a similar-priced model? Also, how many pictures does a 16Mb memory card hold?
Any advice/opinions gratefully received.
Many thanks in advance.
JonR
Posted on: 28 May 2004 by Former member
Jon, I bought an Olympus c-350 a few months ago, and it has all the specs you mentioned. For general photography it's a good camera for beginners like myself. It's very easy to use. As for the memory card, that depends upon the resolution. I've got a 64mb card and at the highest resolution 2048 x 1536 it takes around 20 photos. The lowest 640 x 480 it takes 493! I would advise getting a bigger card than 16mb to be honest. So for a 16mb card divide by 4!
Hope this helps.
Jo
Posted on: 28 May 2004 by JonR
Jo,
Thanks! 20 - 493?? That's a helluva difference in the number of photos just from a change of resolution!
By the way, if you don't mind me asking, is the c-350 about the same price as the D395?
JonR
By the way, forgot to add...
The ideal digital camera should be Mac-compatible.
JonR
Posted on: 28 May 2004 by BigH47
Only if you have a Mac.
...which of course I do. Only the best... Wink
JonR
I bought mine for £120 in cash converters, presumbly second hand, boxed with a warranty etc, but it didn't come with a memory card. One bit of advice, I bought my card at a little photo outlet in Cardiff for £20, literally next door in Comet, they were being sold for £49.99! So shop around. Oh and invest in a lithium battery, I got two for £10 on ebay! I don't have a mac, so have zero clue if it is compatible.
Jo
Jo
Jo, thanks again, some valuable advice there. £120 is the price the D395 is on offer for, so it seems quite reasonable. Assuming I go ahead with the purchase I'll definitely shop around for the accessories!
JonR
