Getting records professionally cleaned
Posted by: Kevin-W on 29 August 2004
Geezers:
I have just acquired six LPs which are absolutely FILTHY. I've tried playing tthem on the old LP12 but they're really noisy and just pile up fluff on the stylus. Ideally they need to be cleaned with a VPI-type machine, but buying one is (obviously) out of the question.
Does anyone know if there are any shops or dealers in London that will give said LPs (which are actually pretty rare and not available on CD) a good once over?
Thanks in advance
Kevin (Depth Charge: Bounty Killer 12")
Posted on: 29 August 2004 by ejl
Kevin,
I can't help you with a dealer, but a couple years ago someone here posted this link to a DIY cleaner:
http://www.teresaudio.com/haven/cleaner/cleaner.html
I made one and it has been great; note that the brush, fluid, and design principle are the same as with the expensive VPI cleaner.
This can actually be done more easily than in the link. I didn't bother making a box but just used an old turntable. I also used a $20 wet-dry vac, which required only minimal modification to the crevice tool (and can be used as a normal vac otherwise).
Eric
Posted on: 29 August 2004 by Not For Me
Kevin,
I could clean them for you semi-professionally with my VPI ? Only trouble is I am not in London until Saturday.
I seem to remember hearing somebody in the Rock & Pop Reckless record store in Berwick Street talk about cleaning the LPs, so that might be worth a try?
Or one of the Jazz type shops, like Harold Moores?
Or a Hi-Fi shop like Grahams perhaps
Good luck anyway
DS
OTD - Green Velvet - La La Land remixes
*** All the views expressed within this e-mail are the sole responsibility of DS, and as such are wrong ***
