Leaving Naim on all the time ...
Posted by: JosephR on 07 September 2000
Will leaving the Naims on all the time increase my electricity bill a lot ?
Posted on: 07 September 2000 by Laxton
Joseph,
I've been trying to find this out too. Looked into all the manuals but i can't find anything that states the power consumption of the equipment. I would attribute around S$50 to the naims. If you've noticed, the electricity tariff just went up last month.
Laxton
Posted on: 07 September 2000 by JosephR
Hi, Laxton, yes I noticed ! My bill now is S$ 460, almost double that of my last month's. Last month was when my Naims came in, so I'm trying to figure out if its the Naims (I leave them on the whole time) ...
Posted on: 08 September 2000 by Former member
This was calculated on the old forum, I forget by whom. Apparently it takes less power than a PC left running. When there is no music playing the power amps draw only enough to tick over. This is supposed to be minimal. So it shouldn't adversely affect your bill.
When my wife stopped doing the ironing the electricity bill plummeted. Irons use a lot of power, more than the hifi.
Tom
Posted on: 08 September 2000 by Andrew L. Weekes
Hi all,
I did some tests a while ago, on my modest system.
The cost of leaving my Nait3 on all the time was more than I thought, but not enough to worry me.
It was a LOT less than leaving a PC on constantly.
I tested a Nait3 and the cost was under 1 unit per day.
My colleague has an Exposure pre-power, and with both units permanently powered, and a Naim CD3 it cost about 1 unit per day (£25 / year @ 7p / unit).
The PC (excluding monitor) was over 2 units per day!
If you live in the UK Maplin sell a 'cost plug' that looks like a mains timer that will enable you to monitor your system - it totally ruins sound quality though, so remove before listening.
Andy.
Andrew L. Weekes
alweekes@audiophile.com
