Gewiss electricity socket
Posted by: Arye_Gur on 19 January 2001
We'd discussed here the difficulties of pluging many boxes to the electricity.
The solution I found is a Gewiss sockets.
High quality modulate base with High quality sockets for all kind of plugs.
There are bases for 4 or 5 sockets - but when use two plugs connector or three plugs connectors in one line, you can locate 2 of them in one socket - and it increases the number of connectors available per a base.
You can easily connect two bases or more and get realy large number of sockets. The bases can be easily mounted to the wall.
Arie
