Concrete blocks
Posted by: Fisbey on 23 September 2004
The grey (medium density) ones (not breeze blocks) - what's the best tool to use to trim an inch or two off them in situ?
Posted on: 23 September 2004 by i am simon 2
Stricktly I am not qualified to answer,and I am not exactly sure as to what you are refering, but my best guess would depend on your skill.
I would have thought a rotory saw with a large enough cutting disc would work, or if you have the correct skill, a mallet and chissel.
Simon
Simon
Posted on: 23 September 2004 by Rasher
You need to hire a disc cutter. Hammer and chisel will break it up too much. There is no other way.
Better still, just get you local freindly builder to do it - it will take them 10 minutes and you can give them a few quid for a drink.
Posted on: 23 September 2004 by Fisbey
Yes I thought as much, the trouble is they're cemented in place with a rafter overhanging the blocks (3 blocks need trimming) - I think if I'm careful I could use a grinder and trim them (an inch or two) - I'd like to say I was in a hurry when I measured up for the decking, but the bloody thing's taken me 2 months!
Oh and the reason need to trim the blocks is so I can fit a plank across the front of the deck and at present the 3 blocks prevent me doing this.
Someone mentioned a saw may cut them?
A saw will cut lightweight aerated thermal blocks, but not medium censity concrete.
Right off to the hire shop, then Ashford hospital!
Yes thanks Tom
Yes thanks Tom
Posted on: 23 September 2004 by BigH47
Don't stain them though!
Posted on: 23 September 2004 by long-time-dead
10" Angle grinder and a diamond tipped blade will do the trick.
Given that they are in situ - use the grinder to take off as much as you can then use a hammer and brick bolster to remove the rest.
Use gloves, goggles etc. to protect any part of your body you want to keep. Flying brick is no fun.........
