Why mono?
Posted by: Steve Shochet on 09 November 2000
Obviously not a huge deal, but it's a question I have had for a while.
Thanks!!
Steve
Jonathan
The mono switch on playback is useful for checking the azimuth of cartridges. On some test LPs, there are tracks that have the same LH & RH signal in opposite phase to each other so that when the stereo signal is mixed in mono, there should be no residual audible output from a perfectly aligned cartridge. Some flat-earthers also don't like to be distracted by things such as soundstage, depth and precise placement of sonic images.
On record, I have found the mono switch useful for balancing the recording levels between L & R channels. With a stereo signal, the twin metering bars bounces in every direction and establishing perfect balance (using off-tape monitoring on a 3-head deck) without a mono switch takes just that little bit longer. The same flat-earthers probably prefer to mono-ise stereo recordings to playback on hopelessly holographic equipment without mono switching.
Hope this helps.
James
1)use the mono switch on mono lps because it will lower the effects of rumble and noise because most of it is out of phase and will cancel in mono.
2)use it on horrible "electronically re-recorded" fake stereo records where they put the treble in one channel and the bass in the other.
--Eric
Steve
I believe those Dexter Gordon records were actually recorded in stereo that way. They are not mono records. Quite a number of 50's stereo is recorded in 2 channels in such a manner - hard left and right with no center. The mono release of these records might even have been preferable as sometimes mono mixes are better than the stereo release.
Paul
Unfortunately I don't have a mono button to try it out myself, but it sounds interesting.
Ciao!
Willem
P.S. Somebody correct me if I'm wrong.
IIRC, for instance, Van Gelder monitored via a single K-horn until 1959 or so, even when he started recording in stereo. So the mono is likely to be closer to what he intended.
--Eric
(in light of his preference of two channel stereo to five channel surround sound)!
You remembered! I feel as though some of this rhetoric isn't ALL a waste of space.
Yes, you're right. The only way to adjust balance accurately is if you have a Mono switch. For those who will say that a Mono record is enough, that's not true since you can't guarantee that the output from a Mono record will actually be accurate for each channel since other issues could be at work such as cartridge out on azimuth, length of speaker cables differ, length of interconnects differ per channel etc. The Balance and Mono switch combination gets around all that.
Frank.
