Linn KATAN, need advice please
Posted by: Gram Parsons on 05 May 2004
Hallo,
please tell me how to remove the grill from the bass/midrange drive unit?
Need advice please......
Ciao
Posted on: 05 May 2004 by Hammerhead
Use carefully – may result in splintering if over zealous ;-)
Maybe the good Dr Randle will be able to offer more constructive advice...
Posted on: 05 May 2004 by Gram Parsons
It's not to remove???
Posted on: 05 May 2004 by Setting Son
Remove the rubber surround - just gently ease it away. Then remove the grill - it is only held in place magnetically (from the drive unit magnet).
Hope this helps.
Posted on: 05 May 2004 by Andrew Randle
Katan's sound fine with the grill on. Better improvements can be made with upgrades to the equipment, stands and mains. I assume you are using the Katan stands too.
Andrew
Andrew Randle
Linn Binn Sinner
Another question?
Does anyone know that older Katans have a plastic tweeter and newer ones a metal tweeter?
