They arent fit!
Posted by: garyi on 17 July 2004
Well, yes they are actually but since I attached a pair of clip in pedals and shoes for my racer I see where at least 50% of my energy has been wasted when cycling.
They make such a difference!
One thing though, when peddling I can feel a bit of movement, I haven't fallen out of them but I can move the shoe in the pedal a bit, is this normal?
Posted on: 17 July 2004 by John Sheridan
it is if you're using floating cleats, or pedals with built-in float.
Posted on: 18 July 2004 by long-time-dead
You'll also find that they will need an initial adjustment after they settle in.
I'm using Look pedals and it happened to me. One small adjustment and they 'snap' in an out now.
Posted on: 18 July 2004 by matthewr
garyi said "I see where at least 50% of my energy has been wasted when cycling"
I think you mean 5%. Or are you going literally going some combination of twice as fast and twice as far?
Matthew
