I would also be interested in what speaker wires people really use and what they would recommend between the amp and speakers
I really use NACA A5 and I really recommend it.
I have used others, QED Profile 4x4 (more expensive), QED Profile Silver (more expensive) and Cable Talk 4.1. I've even tried some kind of solid core but I don't recall the manufacturer. None were as good the the NACA A5.
Getting the best from the CDX? I'd suggest you get used to it for a time. Identify where you think it's lacking (if it is) and investigate supports, either metal or wood. Mine is on a home-made plywood rack and it sounds great. Making sure it's stable and level is a problem because of the wood I used but that's the only problem.
Don't listen too hard for problems, just enjoy it.
Brian
[This message was edited by Brian on SATURDAY 20 January 2001 at 15:59.]
