Which CD's can I buy in America for use here?
Posted by: Fisbey on 06 May 2004
I'm going soon.
Posted on: 06 May 2004 by Dave J
All of them
Posted on: 06 May 2004 by Former member
Fisbey,
May I be the first to say: "Eh?"
nick.lees at btinternet.com
Get the ones that you like.
Buying CD's that you don't like is a very silly move, unless you need to get some new cases.
Posted on: 06 May 2004 by Fisbey
Aren't some CD's 'copy protected' or something that prevents them being bought in the 'states and played here?
Or (quite likely) am I being dumb?
Posted on: 06 May 2004 by Geoff P
Sure you are'nt asking about DVD's instead?
DVD's ARE region coded. Officially DVD players sold in Europe are set to only play European origin DVD's (region 2) whereas US discs are Region 1 which will not play in a player set for region 2 only.
BUT
that is a token gesture to officialdom. Whenever you buy a DVD player in the high street just say. "OK but it has to be multiregion" and almost by magic in five minutes the dealer will turn it into a DVD that can play any DVD disk including those from the US. he just reprograms the control chip inside the player.
regards
GEOFF
BUT
regards
GEOFF
DOH!
That's what I was thinking of, which is strange seeing as I don't even own a DVD player....
Must be suffering with vertigo....
CD's are fine however DVD's and Video's are a different matter. If you have a video it may not play NTSC tapes (we have PAL in the UK) and DVD players bought in the UK do not always play Region 1 DVD's so you will need to check.
Dave
Dave
Posted on: 06 May 2004 by seagull
Have you been sniffing something you shouldn't have?
Posted on: 06 May 2004 by Brian OReilly
CD's are fine, books could be a problem.....
Brian OReilly
Brian OReilly
No I haven't!
Just having (another) 'moment'...
'Moment' is that a hated expression?
Posted on: 06 May 2004 by JonR
Fis,
Though you say it's all down to confusion with DVD's, your question is no less valid. If you pop into the Music Room you'll probably find out why, but suffice it to say that there are various contributors who find that CD's bought in the states (in some cases) tend to be better mastered to a higher standard and therefore sound better than CD's bought from countries in the EU.
Probably worth getting a few tips from those in the know!
BTW...
...welcome to the Padded Cell!!
JonR
BTW...
Originally posted by FISBEY:
No I haven't!
JonR
Brian OReilly
