Rasher
Posted by: Fisbey on 11 October 2004
I got the name of the solo Chick Corea CD wrong - It's Expressions!
If it helps I can get a copy burnt for you?
Let me know if you do.
PS Not sure if burning id acceptable really, but if you can't get a copy....
Posted on: 11 October 2004 by Rasher
Expressions, eh?
I don't know that one either, but will look it out at my local shop. It seems to be expensive at Amazon, and I may not like it all that much. Tricky.
Thanks Fisbey.
