Anyone Familiar with Dynaudio Contour 1.8's. Speaker Grilles on or off?
Posted by: Jaybar on 25 December 2000
What is usually recommended for these speakers? They are firing straight ahead in a slightly hard room.
Jay
Posted on: 27 December 2000 by Arun Mehan
If you post this in the Hi-Fi Corner, I'm sure you'll get a response. On the whole though, I prefer the grilles off.
Posted on: 28 December 2000 by Pete
...why do you care what anyone else thinks? It's your ears and your music, so try them either way and go with what you prefer. Not exactly a difficult test to try for yourself, after all, and in your system your opinion is the only one that matters.
Pete.
