Prefix problem: not enough gain...
Posted by: mmhifi on 19 August 2000
Hi,
I did full conversion from sucking digital to vinyl. I bought 2ndhand 1983 LP12/Valhalla/Ittok LVII. Yesterday my dealer made exellent job by
installing Cirkus and new Klyde mc cart and did full table/cart retuning. As phono stage he installed new K-type Prefix inside plinth which is powered by HiCap from dedicated ac line.
From Prefix signal runs to Ensemle Tiger integrated and Ensemble Reference speakers. Sound quality of this installation I grade from good to astonishing and depends mostly on record quality and condition. But I have one caveat:
there is not enough gain in Prefix for low-output Klyde. With fully open Tiger I can get
"normal" volume level and not 1db more. True
it's mostly fine for classical and jazz but not
for rock where additional 2-3db are not superfluous. And it's fine to have 3-6db of reserve in any case,isn't it? Is it possible to get more juice from Prefix? I can change phono pre(cart and amp are not options) but prefer to stick with Naim because of sound quality it provides.
[This message was edited by mmhifi on SATURDAY 19 August 2000 at 15:25.]
Posted on: 19 August 2000 by Paul B
Your problem has not been mentioned before as far as I can recall. The Prefix should have enough gain with the Klyde. There is also a Prefix S type with slightly different loading but the gain is the same I believe. Either there is a fault with the Prefix/Klyde or the problem lies elsewhere (in the preamp?).
You should contact Naim directly, perhaps.
Paul
Posted on: 19 August 2000 by mmhifi
Not likely. Tiger is absolutely happy(on same input too) with cd and tuner and Prefix/Klyde provides performance to die for without any channel disbalance - but where can I find those 3-6db ? Additional tip: Linto has 64db of
gain for Archiv/Klyde and Prefix...56db - exactly
what I miss.
Posted on: 19 August 2000 by Former member
First off, you should be using an "S" Prefix with the Klyde and not "K". Although it will not solve your gain problem, things should sound better. As for gain, you may want to consider more efficient speakers. I have no problem whatsoever achieving insane volume levels with my Prefix.
Vuk.
How do you know "S" will be better? Did you do
test on same system? I feel mine sounds right and
I have no RFI problems or something. I never seen
Naim did claims on "K"/Klyde/Arkiv incompatibility
and it seems to be legend. Your advice on speakers is funny, mine are 90db/w and amp is 60w/ch - and it's not option, because I don't
know of better speakers(except Ensemble Elysia).
Posted on: 20 August 2000 by Former member
Joe Petrik carried out this test for me (his old 32.5 could take two sets of boards at once) and "S" were better with the Klyde. They are also the boards recommended by Linn/Naim for that cartridge. The "K" will not sound bad, but they do not work as well.
I did not mean to be funny. You are complaining about insufficient volume and getting more efficient speakers is one way to solve that.
Vuk.
Posted on: 21 August 2000 by David O'Higgins
How can I tell whether I have an 'S' or a 'K' prefix and which should be used with a Lyra Clavis DC ?
