Pssssssssssssssssssssss
Posted by: Steve B on 01 August 2004
Just fixed my first puncture today. Luckily I was at home when the tyre deflated ('cos that's when I pulled the thorn out).
Anyone know if the self repairing inner tubes are any good? Fixing a rear puncture would be a hassle and quite messy out on the road I'd imagine.
Steve B
Steve B
Posted on: 01 August 2004 by John Sheridan
Steve B
not that much hassle with a bit of practice (or you could just replace the tube like the rest of us lazy folk). However, if you don't want punctures then you should invest in a set of armadillos or similar.
Posted on: 01 August 2004 by Tim Jones
Ah, well, there is stuff called 'Slime' (TM) that you fill your inner tubes with, so as to make them (theoretically) self-sealing. Can't remember who makes it.
But it's a pain. I'd rather fix the occasional puncture (and you get used to/better at it with time) than mess around.
Tim
Tim
Posted on: 01 August 2004 by 7V
We've got one of those trendy three wheel push-chairs (ideal when you go out jogging with the baby
Anyway, we used the 'Slime' stuff and it works quite well. It's not too much hassle if you follow the instructions. You can buy it in Halfords.
Steve Margolis
defy convention - make music
Posted on: 01 August 2004 by Steve B
John,
What are armadillos?
Steve B
Posted on: 01 August 2004 by glenda
Posted on: 01 August 2004 by ErikL
Mr. B,
I recommend carrying a spare tube, and repairing any blown tube once you return home. This is the low stress way.
Posted on: 02 August 2004 by Steve B
I've just fitted the self healing tubes. I'll still carry a spare though just in case.
Those tyres look interesting - thanks Glenda. I'll wait until my current ones wear out though. I don't want this cycling hobby to become an expensive one. (One expensive hobby is enough for me).
Steve B
Steve B
